Huawei E5830, E5832 & E5838 Free Unlock
  • daemonsyn
    • Sep 2012
    • 4
    #331
    Hi All,
    Modem Info
    Found modem : E5832
    Model : Huawei E5830/E583x
    IMEI : 354104036385484
    Serial NR. : Z8A4CC1183000026
    Firmware : 676.11.17.07.108SP02
    Compile date / time : Sep 23 2009 21:15:43
    Hardware ver. : WLC1GCPU
    Dashboard version : UTPS16.001.06.05.256_MAC16.001.09.06.256
    Chipset : Qualcomm MSM7625A
    SIM Lock status : Locked (Card Lock)
    It has a custom dashboard from SUN Cell PH.
    I can't access 192.168.1.1/simlock.asp neither 192.168.1.1/en/simlock.asp
    I tried using 'CardLock_UnLock' using the codes below:
    76450213
    27563347
    Doesn't work. (Failed)
    Here are my logs.
    Download e5832.rar from Sendspace.com - send big files the easy way
    • Jim.Mahoney
      • Feb 2010
      • 4249
      #332
      Originally posted by daemonsyn
      Hi All,
      Modem Info
      76450213
      27563347
      Here are my logs.
      It's the wrong code that's why! Your unlock code begins with 93
      • daemonsyn
        • Sep 2012
        • 4
        #333
        I found it.
        93067499
        Almost used up the tries. =)
        • Digicom
          • 190
          #334
          HI Jim
          Is it possible for you to obtain code from log below plz?
          Thank you
          Download Huaweilog.rar from Sendspace.com - send big files the easy way
          • Jim.Mahoney
            • Feb 2010
            • 4249
            #335
            Originally posted by Digicom
            HI Jim
            Thank you
            This EFS is way to small... It needs to be between 700 and 780K in size before you Zip/RAR it...
            • inertiadrift
              • Oct 2012
              hello please help me unlock:
              IMEI : 354104034365264
              Serial NR. : Z8A4CC1140800603
              Firmware : 956.11.109.02.309sp01
              Compile date / time : Dec 27 2010 14:02:58
              Dashboard version : UTPSTOOL-ConnLaucher_WIN1.01.02.00_MAC1.02.05.00
              • jstrevor
                • Oct 2012
                • 27
                #337
                00 4F 63 74 20 32 39 20 32 30 30 39 30 39 3A 35
                36 3A 32 30 4A 75 6E 20 31 32 20 32 30 30 39 30
                35 3A 30 30 3A 30 30 53 4E 43 41 41 4C 5A 4D 00
                00 0D 00 00 00 01 B1
                .Oct.29.200909:56:20Jun.12.200905:00:00SNCAALZM... .....
                I think my unlock is 13551008
                I would be greatful if someone could confirm before i try?
                Using e5830
                thanks in advance
                • Jim.Mahoney
                  • Feb 2010
                  • 4249
                  #338
                  Using e5830
                  thanks in advance
                  Try reading the guide again... What's shown here wont give you your code!
                  • prontus
                    • Oct 2012
                    Huawei 5832S unlock
                    Hi, I've read the forum and still did not get the picture which is the easiest way to unlock Huawei 5832S router. Would anyone please comment / oint me to an answer? Thanks!
                    • Jim.Mahoney
                      • Feb 2010
                      • 4249
                      #340
                      The sure fire way if you don't want to mess around: Huawei Modem Codes
                      They charge ?3.50 per code which is around the cheapest I've seen!
                      • cocodon
                        • Oct 2012
                        can i use this on a mac?
                        • Jim.Mahoney
                          • Feb 2010
                          • 4249
                          #342
                          Yes, they have a code entry tool for a Mac: Huawei Modem Codes - T&C
                          • Jim.Mahoney
                            • Feb 2010
                            • 4249
                            #343
                            Nice, not stunning but nice...
                            • caniculabv
                              • Oct 2012
                              I can install QMAT, it give's me an error, i have win 7 x64.
                              • Jim.Mahoney
                                • Feb 2010
                                • 4249
                                #345
                                It does not work with Windows 7 properly or 64 bit! Try running under Windows XP 32 Bit.
