Help Newby to Satallite
Thats the way I do it now if im fitting one for family or friends although I try to get out of it, when youve fitted one or two it becomes easier and no need for meter etc. you have an idea.
Motor dish no need for me to put one up have trouble watching the tv that I have got
dishpointer.com is also a guide site to use to get a rough direction to point the dish.Hi
The best way is to get an extension lead set you tv and sat box up so you can see it up the ladder. You can really get your tweak on then!
Wouldn't say you have to go for the 10. The 9 would do fine for hiss needs really. Depends on how hip and cool he wants to be but if you want to spend the least amount of money and get same results then by then buy the openbox 9.sigpic
Patience is a virtue.Comment
s10 has only hdmi outputs , no outputs for sound to an amp , and no scart , the s9 has all 3 connections , although the s10 is much prettier and guess support will be aimed more at the later model than the older one ,
if scart is important get the 9 , if its for use to a hdmi panel only, get the 10 , if you wanna research them a bit more , we have a openbox forum here too
Openbox
pics here if you wanna compare size
Agreed that you dont have to go for the S10 and the S9 would be fine but Im just a sucker for newer models, If Im gona buy something I always buy the latest one. Did someone say size matters
I am not sure you realise that what you heard is not what i meant ! sigpicComment
If its any help ive a standard motorised 1 metre set up with a twin Lnb.One line comes in my bedroom,the other the lounge.
Ive a box in both rooms but only the lounge box will move the dish and obviously you can only watch the same sat on both boxes,
As for cline you will need to google it or google card sharing.
We can only say so much on this forum mate.
Andy,New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
