latest blade 7000 patched firmware(13/9/2011)
  • needy
    • 105
    #91
    HI GUYS I CANT DOWNLOAD THE LATEST PATCHED FIRMWARE IT JUST SAYS THE FILE IS CORRUPT WHEN I TRY TO UNZIP IT, ANY THOUGHTS THAMKS
    • ulrich100
      • Aug 2010
      • 29
      #92
      Originally posted by idxinfosys
      Hi Thanks, I tried that previously and got the exact same result.... also I tried putting in an ip address instead of the server name made no difference.. I may have to try an older router I have. I have servers running through this Dlink router and have never had a problem.... very strange....
      I have had a similar problem, tired for days to get a stable conncetion to my router. turned out that it was a hardware fault at the NIC.
      Seems there is a batch doing the rounds with the same problem.
      If the ethernet cable is only partial inserted I get a connection (orange light on, visable IP) if it is propery enbedded (clipped into place) there is no cennection to the router (thus no IP)
      I guess its to do with the soldering of the connections points. Or the NIC itself is 'defuncked'
      Anyhow, I need to get on to my supplier for a new box.
      • idxinfosys
        • Oct 2011
        • 10
        #93
        Use my link a few posts earlier, i had the same problem.... found a working version on another site and posted.
        • edwardihno
          • 6
          #94
          hi all was thinking about getting one of these, i used to be into cable until all that dried up, not got a cline but can this box be used to open any euro sats with patched firmware alone. don't expect full explanation but a nudge in the right direction would be much appreciated. many thanks in advance
          • singhisking
            • Nov 2011
            #95
            try using Winrar to unzip it rather than winzip.
            • zee24
              • 3342
              #96
              this 1 aint the latest firmware anyway the october 1 is the latest
              • thisisanswwer
                Use the very latest patched firmware attached, using it currently and is great.... no problems so far.
                many thanks
                • kapadia
                  • Feb 2011
                  #98
                  i have problem with bm7000s all hd channel keep freezing i got vm super hub with 100mb some hd channel work fine and some keep freezing i dont know wats wrong ??/
                  • kapadia
                    • Feb 2011
                    #99
                    bm7000s some hd channel freezing
                    i have problem with bm7000s some hd channel keep freezing s sport hd 1 keep freezing but ssport 2,3 and 4 hd working fine same way in movie as well i have vm super hub(netgear) with 100mb and box firmware 122p 25-4-11 pls help . . . on this
                    • zee24
                      • 3342
                      #100
                      you have the old firmware for starters, but i dnt think that would effect the freezing
                      • irishbluestaffy
                        • May 2010
                        • 611
                        #101
                        must b yr server m8
                        • ramjet
                          • 2995
                          #102
                          just the remaining ucas channels that are opened using a softcam , so not a lot to be honest , you would really need that C jobby
                          • ramjet
                            • 2995
                            #103
                            update your firmware to october , and check your signal and quality levels are ok , if they are then its your server at fault
                            • mrjai66
                              • Apr 2010
                              • 4
                              #104
                              hi guys wondering if anyone has up todate channel list for blade including all asain channels as some of mine are blank.
                              many thanks
                              • usman786
                                I just installed BM7000s-05-10-11-7ex.zip, without any factory reset, it kept all settings and channels. Youtube is very clear at highest quality when the clips plays otherwise you have to reboot box.
