Openbox S10 Front of Box saying ON ??
  • hooley
    • 470
    #61
    Originally posted by sujee776
    i tried all the softwares there is to fix the s9, nothing works. it just says stb error. i even took it to the supplier he said flash memory is messed and i cnt do much. is he chatting crap? is there anyway i could fix this
    Are you using a USB adaptor or is it a dedicated serial port?
    • sujee776
      • Apr 2011
      • 24
      #62
      im using dedicated. i have tried it on dm800 it works fine
      • sujee776
        • Apr 2011
        • 24
        #63
        Originally posted by slugworth
        When I killed my s10 I downloaded various kits to fix it and some gave me that error.Seems the kits were missing ini files or had the wrong ini files for my receiver.The loader should include the eromclient.abs which has to match the amount of ram in the receiver,ditto for the sdram.ini.You must start the loader first,then turn the receiver on with the switch in the back.Reanimator openbox has the files built-into the loader itself, if you can find that one.
        i tried the reanimator it says target not found or target error. i know my port works bcoz i use my dm800 on it
        • slugworth
          • Nov 2011
          • 1064
          #64
          null
          I assume you are using the correct serial cable,null modem.
          A terminal program on rs232 should show some life on the rs232 port when you turn on the receiver.This shows you are using the correct cable and there is hope.
          • binary
            • Mar 2009
            • 121
            #65
            rs232 reloading satellite box software
            HI your transfer speed is not set to high is it? i would reduce it to 56000 or less it may need time to "handshake" the box
            • slugworth
              • Nov 2011
              • 1064
              #66
              shakes
              You have to match the baudrate of the receiver,which is 115200
              A terminal program when connected will say app init ok,which means the rs232 cable is correct,baudrate correct,com port working.
              • pa8style
                • Jan 2012
                Anyone know where I can get a clone safe firmware?
                • Manic01
                  • 5117
                  #68
                  Search facility or google.
                  • slugworth
                    • Nov 2011
                    • 1064
                    #69
                    s10
                    the hacked s10 is supposed to be clone safe.
                    • mmdeen1981
                      • Jan 2012
                      #70
                      iam also facing the same problem in my new openbox s10. it displays ON. but the box id shows it is a original. any Idea???
                      • mmdeen1981
                        • Jan 2012
                        #71
                        wat will be the drawback when it is CLONE???
                        • konami001
                          • 10
                          #72
                          Clone boxes cannot support the new features and bugs fixing which are introduced with new firmware upgrade...
                          • RicHard59
                            • Oct 2011
                            • 5
                            #73
                            If your box is a clone and you install new hardware, there comes also Blade Runner and retires your clone with clonebomb.
                            • sptvlhr
                              • Jan 2012
                              i want to download these software
                              • exey
                                • Dec 2011
                                Thank you very much
