Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • samheel
    • Dec 2012
    i have just experienced this problem,. do i have to used the re323 wire or can i used another
    • jaybou
      • Dec 2012
      • 6
      #227
      Has to be done via rs232
      • kadnor
        • 78
        #228
        No Channel display S 9 Hd
        Hi,
        About Bootloader, how to include same with image.
        THKS in advance.
        Originally posted by slugworth
        use the correct loader or turn the receiver on slower
        • L33TRB
          • May 2012
          • 5
          #229
          Will using a "USB 2.0 to RS232 Serial DB9 9 Pin Female Adapter Cable"
          Do the same job? As I have no RS232 connection on my laptop so will have to be USB.
          • slugworth
            • Nov 2011
            • 1064
            #230
            I never got it to work with an adapter.
            • ptthomasow
              • Dec 2012
              is this method applicable to skybox f3?
              • slytherine
                • Dec 2012
                this the updated firmware??
                • riandi
                  • Dec 2012
                  There's no dump or update firmware via usb menu on my S9 so I decided to update the firm ware via null modem cable. I got this message :
                  "synchonizining STBs
                  please reset target!!"
                  I'm using right null modem cable. Any help would be appreciated
                  • slugworth
                    • Nov 2011
                    • 1064
                    #234
                    turned the receiver on too soon
                    receiver has to be off when you hit next on the loader
                    • sayeef
                      • Sep 2009
                      • 23
                      #235
                      I just fixed my box with a USB to Serial!
                      I cant believe it!
                      • patslfc
                        • Mar 2012
                        • 7
                        #236
                        I cant believe it!
                        HOW HAVE U DONE THAT BEEN TRYING FOR HOURS
                        • walkaton
                          • May 2011
                          • 67
                          #237
                          if you follow the how to and wait 10 seconds before switching box on and waiting again for bootloader to install then you will have success everytime
                          • madcatz
                            • Jan 2013
                            I got the same problem but still stuck with stb memory error
                            • Phooey
                              • Dec 2012
                              #239
                              I have the same problem with skybox f3. It stops at Load screen, i will try your fix and let you know if it works.
                              • Phooey
                                • Dec 2012
                                #240
                                Beats206, your info is perfect it worked a treat cheers.
