Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • nedec
    • Oct 2012
    Originally posted by bengak
    Hope works fine...use loader below..for dead S16..and this newest S16 f/w v2.4
    is it working on openbox s16
    • starlite7
      • Feb 2011
      • 13
      #137
      Hi
      i have read the other threads but it seems I have the only S11 receiver that wont re-flash/recover,
      Does this recover a receiver that appears completely dead ie nothing showing at all, I have voltages inside the box so I presume its corrupt firmware,
      Could some one point me in the right direction of a suitable firmware, members have had the same problem but have found firmware that works,tried several off this site but to no avail about to use the s11 as a door stop, trouble is its not summer.
      Any help would be nice
      • balchohan
        • Oct 2012
        Dead S10 BOX
        Hi, How do I bring my box back to life?
        • mast
          • Nov 2010
          • 1027
          #139
          Hi
          All the info that you need is in this thread if you read post 1 should give you an idea.
          Also a bit more info as to what box and whats happening with it, is it stuck on "ON" or dead and if dead have you tested the power supply.
          Regards
          • mast
            • Nov 2010
            • 1027
            #140
            Originally posted by starlite7
            Hi
            Hi
            You say you have voltages but are they the correct voltages.
            Also if you know what firmware was on it when it died then you should try that as I think thats whats brought some people success with really stubborn boxes.
            Regards
            • mast
              • Nov 2010
              • 1027
              #141
              Originally posted by faisalali
              having same issue as as saying stb reset target
              Hi
              Sometimes its the timing, so you need to try different timing sequence and perseverance/patience to get loader going.
              Regards
              • sailsy
                • Mar 2012
                • 145
                #142
                I have already said thanks but would like to post also hope you dont mind mods!
                Followed instructions as per page 1 the way it went for me was started as stated clicked next then turned on nothing seemed to happen for 10 secs then all went smoothly!
                so just chill out and be patient forgot to tick bootloader first time but second go dead s10 alive again.
                many many thanks!
                • slugworth
                  • Nov 2011
                  • 1064
                  #143
                  most of the time people turn the receiver on too fast.
                  You have to start the loader then turn the receiver on at a casual rate.No hurry,it gives you a long time.I have started the loader and forgot to connect the rs232 cable to the receiver.I still had time to do all that and it loaded.
                  • buozzi
                    • Sep 2012
                    #144
                    Hi,
                    can the erom_upgrade_8Mflash work also with Openbox S16?
                    Thanks.
                    • slugworth
                      • Nov 2011
                      • 1064
                      #145
                      s16 uses it's own loader or the old s10 loader v2.0.0f
                      • buozzi
                        • Sep 2012
                        #146
                        Thanks Slug,
                        but is normal that when openbox is connected to pc with nullmodem cable, it doesn't switch on? That is, I switch on button on the back, but display remain black. If I disconnect cable from pc then the openbox switch on.
                        • starlite7
                          • Feb 2011
                          • 13
                          #147
                          Hi
                          Tried all above ideas but still no joy,
                          The lead is correct as i have used it on others, but I cant remember the last firmware so I have given up and its beaten me, spending to much time on it.
                          Has correct voltages without a diagram, I can only test the 240v
                          Thanks for help
                          • wariot666
                            • Oct 2012
                            #148
                            Originally posted by beats2006
                            Ok I was having the same problem and just fixed it finally after a lot of trial and error heres what I did -
                            downloaded http://www.digital-kaos.co.uk/forums...de_8mflash.rar
                            then downloaded some older firmware -
                            SKYBOX_3601hd_CMT_120820071a.abs
                            (if you search google you will find it)
                            Then I plugged the box in and attached the null modem cable,
                            opened up the erom upgrade folder and ran CONFIG.BAT
                            then ran EROMUPGRADE
                            Selected the firmware I downloded
                            Ticked Include Bootloader
                            Clicked next
                            when it says-
                            synchonizing stb
                            Reset target
                            I unplug and replug the power cable out of the back of the box quite fast it will then let you carry on and recover the box
                            once recovered you can update to a later firware via usb or the X3 Lan tool.
                            hope this works for you as I was pulling my Hair out yesterday
                            Thank you soooo much mate!!!
                            I tried probably about 10 diferent software to reflash my skybox m3 and every single time Ive seen "set stb memory error". I thought Ill try last time and if that doesnt work Ill binn this box.
                            NOW Everybody who has the same problem!!!
                            Every single instruction I founded on how to do it, there was no mention about running config.bat before you start, there was not even config.bat included.
                            After running config.bat, first attempt to flash my box and it worked for me!!!
                            I cant thank you enough. You are the star!!!!!!!!!!
                            • slugworth
                              • Nov 2011
                              • 1064
                              #149
                              the config.bat just sets the correct files to use,which may be included already set in some loader packages.The eromclient.abs has to match the processor in the receiver and vary in size depending on the processor/receiver you are trying to flash.
                              • wariot666
                                • Oct 2012
                                #150
                                Im not very good with all this...
                                It might even be just good luck but it was only one which worked for me...
