Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • slugworth
    replied
    turned the receiver on too soon
    receiver has to be off when you hit next on the loader
    Leave a comment:
  • riandi
    replied
    There's no dump or update firmware via usb menu on my S9 so I decided to update the firm ware via null modem cable. I got this message :
    "synchonizining STBs
    please reset target!!"
    I'm using right null modem cable. Any help would be appreciated
    Leave a comment:
  • slytherine
    replied
    this the updated firmware??
    Leave a comment:
  • ptthomasow
    replied
    is this method applicable to skybox f3?
    Leave a comment:
  • slugworth
    replied
    I never got it to work with an adapter.
    Leave a comment:
  • L33TRB
    replied
    Will using a "USB 2.0 to RS232 Serial DB9 9 Pin Female Adapter Cable"
    Do the same job? As I have no RS232 connection on my laptop so will have to be USB.
    Leave a comment:
  • kadnor
    replied
    No Channel display S 9 Hd
    About Bootloader, how to include same with image.
    THKS in advance.
    Originally posted by slugworth
    use the correct loader or turn the receiver on slower
    Leave a comment:
  • jaybou
    replied
    Originally posted by samheel
    i have just experienced this problem,. do i have to used the re323 wire or can i used another
    Has to be done via rs232
    Leave a comment:
  • samheel
    replied
    Leave a comment:
  • jaybou
    replied
    FIXED
    Finally sorted.Had to data dump from box bought from same shop and flash faulty box with it.No other image would work and believe me I tried about 60 different images from various sources.Now a happy bunny.
    Leave a comment:
  • slugworth
    replied
    the loader gives you minutes to turn the receiver on.
    some people turn it on too fast
    Leave a comment:
  • robertsy
    replied
    Hi i recovered my F3 with software (erom_upgrade_8Mflash) flash with latest firmware it all about timing when you select next and power box on.
    Leave a comment:
  • jaybou
    replied
    still doin me head in
    Im using that and an rs232 to flash but every file ive flasged to it wont work,keeps either rebooting or wont power on.
    I can lend a box bought from same shop- is there a way i can copy the firmware from that box onto faulty box??
    Leave a comment:
  • slugworth
    replied
    for dead receivers you must use loader v2.0.0c,the version where you select the file to upload on the 1st screen.
    This will fix receivers that even have a blank flash.
    If that doesn't work you are using the wrong cable or have a hardware problem.The receiver will have a blank display and never say boot all the time after multiple power cycles.
    Leave a comment:
  • fasgen
    replied
    hi
    i have read all 15 pages here but didn't get clear answer...
    i have an openbox s11 which shows "boot" all the time when powered on. I've tried few different upgrade tools via rs232 (im using the "real" com-port) but all i got is the message - "com test error" or "set stb memory error"
    have tried different timing powering on the box still no luck..
    Is any good working tool for s11 because with one tool i got com error with another stb memory error, with one i even had "raw file error".
    need your help guys!!
    Leave a comment:
