they say the loader doesn't work very well with usb adapters.It is often cheaper just to pick up a cheap old pc instead.
Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
openbox s10 - clone bricked - can you help??
Hi Everyone,
I have an openbox s10 clone. I upgraded the firmware on it using a USB key and now it is dead as dead can be.
I have an RS232 cable and I was wondering if anyone can direct me as to how I can down load firmware loader software and also the latest working firmware for the openbox S10 clone.
I have tried to save items from the links, but on this forum but I've been advised I have insufficient privillages.
Thanks in advace for any assistance you can offer.
Bob
this guide works!. i just used it to repair my s10 after a bad firmware! only want to add that i had to put the serialport in even mode (on the computor) and do a second uppdate and add the #include bootloader" option.now it,s running again.thanks mate!Comment
disconnect lnb wire reconnect again hopefully it should be ok . switch off befour disconnecting lnb wireI have the constant reboot issues too on an s11 box.
Have tried removing the dish cable, but each time I go into the menu and try to getting to system setting, the box reboots.
Am now trying to flash using a null model cable, but it's stuck at 99%.
Any advice anyone?
Thanks in advance.Comment
I've been trying for a while but doesn't want to guess. Actually I am not sure if my serial cable is null mode.Comment
Hope works fine...use loader below..for dead S16..and this newest S16 f/w v2.4Comment
