Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • volex77
    • Aug 2014
    #676
    hi my box keeps saying STB memory error tried to run bat file but bat file will not run anybody help
    • volex77
      • Aug 2014
      #677
      can anyone help when i try to install new firmware i get message saying STB memory error tried to run bat file but can not get it to run how can i get it to run
      • mastercare
        • Sep 2012
        • 5
        #678
        Originally posted by lestasmsc
        Thank you... but what did you write on? Directly wrote .bin files?
        i used openbox firmware the bin file as u said but as i said it was ages ago...hope you have had luck..
        cheers
        • fazz69
          • 160
          #679
          Is there any fix for this. my Open-box V5s has gone dead, but there is a Dim Red light on the front display. i have downloaded every software to Bring the box alive using the null cable but no joy. i don't know if it a hardware problem on the motherboard, maybe a component might need changing but don't know????
          HELP Needed.
          thanks..
          • P&D
            • 2686
            #680
            HELP Needed.
            thanks..
            Not sure if this will help but might point you in the right direction
            Sounds like it could be hardware not software
            • oweny
              • 71
              #681
              higuys my box is stuck on load and none of the instuructions how to sort it works ive downloaded the tool and the firmware and still nuthing thx
              • oweny
                • 71
                #682
                i have tried the above over and over again on my skybox f5s and still says load nothing happining in the programme can any1 help thanks
                • plasterer
                  • 1631
                  #683
                  are you useing a proper 232 cable mate or usb one ....................Paul
                  If your Happy with the Help push the Thanx button
                  PAUL
                  • gorgon777
                    • Oct 2013
                    • 5
                    #684
                    After downloading the new channel list from AJ, and uploading via the Tool, the box has stopped loading. It just quickly flashes the word 'Load' on the box then restarts again. I tried using the RS232 cable with the tools mentioned in the thread but still nothing. I always get a STB memory error. Is there a fix for this?
                    • oweny
                      • 71
                      #685
                      i have downloaded everything i need for my sky f5s box and i still get nothing
                      • viper76
                        • 4
                        #686
                        I have Skybox F5 I updated it using usb when the update finished the box restart it self and it load to 97 and stops I left it like this for about 20 minutes nothing happen than unplugged it from the main and plug it on the same happen it loads to 97 and stops on 97 it just stock on 97 .
                        I tried the above using a usb to serial on a laptop it loads the firmware to the box but what happen now is the box will load to 97 and start again and again I tried different firmware versions and different upgrade tools the result always the same any help please .
                        • Hadron
                          • 2102
                          #687
                          The same thing happened to my clone F5. It was due to trying to flash it with genuine firmware.
                          When I used the latest firmware from HDDVBSW,COM it flashed OK.
                          • viper76
                            • 4
                            #688
                            Thank you for the speedy reply I have flashed it with firmware from the above website but the box loads to 97 and just stops there .
                            I think at could be a hardware problem anyone have other ideas .
                            I managed to bring back to life using this firmware
                            • tabletop
                              • Jun 2009
                              • 40
                              #689
                              hello, I managed to get dead skybox f5s loaded, it now says noch, its for my neighbour and he had all the portuguese channels on the box before it died, has anybody got a link for how to load a channel list for these channels. I have only delt with the sky channels before, this is new to me. Thanks in advance.
                              • vijayintel
                                • Dec 2014
                                I have tried the above step. but Synchronizing STBs done message not coming. any other option
