Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • P&D
    replied
    Originally posted by eyesonly
    I wonder if any one can help me?
    I have a old Skybox f3 and after updating the channels is now stuck on a reboot loop, so i can't connect to it over ethernet!
    Tried to reset it over RS232 and it seems to be doing all the right "noises", I get:
    Synchronising STB - Done
    Check serial [port status - Done
    But then i get
    Sending address command failed
    Can't work it out it doesn't seem to matter what image i try it always seems to give me the same result!
    Any Ideas
    Thanks in advance
    Which program are you using to flash it (There are 2 & if i remember right one works with the F3) i always had problem with the other
    for the life of me i cannot remember which i used
    also are you using USB to COM
    What firmware are you trying to flash
    Just had a search of DK & the software both loaders & software i used So i know they work 100%
    A how to guide on how to fix a corrupt firmware image in OpenBox S9/S10/S11/S12 and Skybox S10 F3 F4 F5 F5S A3 etc. Even if it seems bricked. Box does not respond or displays On or rebooting constantly ? If your box does not respond, or no displays light there is a good chance the current firmware on the box is somehow
    Leave a comment:
  • eyesonly
    replied
    But then i get
    Any Ideas
    Thanks in advance
    Leave a comment:
  • spunlock
    replied
    no need for help now... as found out box is a clone and beyond recovery
    Leave a comment:
  • P&D
    replied
    Originally posted by sebmjomba
    Greetings all
    Am in need of a recovery tool for open box v8 combo. The stb is bricked during software upgrade.
    Thanks.
    Not sure if this will work with your box but you have nothing to lose Click Here (STB Editor)
    Firmware Click Here
    Leave a comment:
  • P&D
    replied
    Only way to find out is flash it...nothing to lose
    Leave a comment:
  • spunlock
    replied
    hi, just a quick question......... my power in my house went off the other day, and when came back on the f5 box i have went in a load loop, then the power pack for it packed in . so i then used another power pack and now the box loads up and is stuck on L100, will the null cable un brick this, or is it fried due to power going off P.S i wasnt doing an update i was just watching tv.....
    Leave a comment:
  • sebmjomba
    replied
    Bricked Open box v8 combo
    Greetings all
    Thanks.
    Leave a comment:
  • Gooner71
    replied
    Originally posted by miktang
    Just in case anyone was interested, the capacitor that blew was 1000uf 10v and cost only 89p and took half hour desoldering old one and soldering new one on.
    Just fixed an s10 with the identical cap blown ! definitely a suspect batch of components at one point or under rated !!
    Leave a comment:
  • z11
    replied
    Has a fix been seen yet for the `non recoverable` dim red led yet?
    Heard poss heat/reflow to the main chip?
    Leave a comment:
  • Duktor
    replied
    looking forward to try this as my skybox is not working at present , such a fantastic forum
    Leave a comment:
  • miktang
    replied
    Hi all
    the replacement psu has arrived and has been fitted to the box and everything is back up and running!!!!
    I am going to look into buying the capacitor and repairing the old board and then sell it on.
    I was in too much of a rush at first to get the box up and running but now its done i will have a go at repairing the old one!
    Leave a comment:
  • slugworth
    replied
    somebody once said there were bogus capacitors out in the market years ago that weren't up to spec.
    The voltage rating wasn't what was printed on the cap,such as a 15v cap was only really rated for 12v so they failed after x amount of time.
    Leave a comment:
  • miktang
    replied
    Thanks to all, the forums pull me through again!!!!
    Leave a comment:
  • miktang
    replied
    Hi all
    Originally posted by Hadron
    Looks like a that domed capacitor is your problem. It's a pity you didn't look at it before buying another board. You could have repaired it for less than ?1.
    If you don't know anyone that can repair it, you could get a few ? back by selling it on Ebay. Someone will buy it & repair it.
    Leave a comment:
  • Hadron
    replied
    Thanks DW190, i looked inside the box and on the psu board there is one that looks a lot more rounded on the top compared to the others which are all flat on top. Hopefully then my new psu should fix this...fingers crossed!
    Leave a comment:
