Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • patslfc
    • Mar 2012
    • 7
    #241
    all i have is a usb to serial cable for my laptop i need to do this box its taking the piss !!! any ideas
    • slugworth
      • Nov 2011
      • 1064
      #242
      make friends with somebody with an old pc with real serial port.
      • elkens
        • Jan 2013
        so a USB to RS232 cable work?
        • slugworth
          • Nov 2011
          • 1064
          #244
          an old pc is often cheaper than a converter.
          I got mine at the town dump for free.
          • msianep
            • Jul 2012
            My openbox s10 failed to boot. (the openbox s10 display panel - "boot" and then blank).
            i tried the solution http://dc347.4shared.com/doc/6Ybt4FvX/preview.html
            but, it stopped there in this step http://dc347.4shared.com/doc/6Ybt4FvX/preview_html_m35c482ad.jpg
            any help here?
            problem solved after having changed the power supply board.
            • aky101
              • Jan 2013
              Im getting this l097 hanging problem after a firmware upgrade on my skybox f3 ive tried flashing it many times with various firmwares with my null modem cable but cannot get it to work it just boots gets to l097 and then back to loading again! any ideas?
              • 1AA
                • Jan 2013
                How to recover from a dead skybox M3, rebooting every time it reaches L100
                • stratosi
                  • Jan 2013
                  #248
                  chip ALI M36018
                  Hello everyone and congratulations x an excellent forum.
                  Given that I read all the posts related to the resuscitation of this skybox rs232 m3 and I carefully followed the advice. I even opened the decoder and the cooler under the initials of the chip is SIGNED ALI M36018. I think maybe I should look for the right config x eromupgrade.
                  thanks and regards to all ..
                  • amsterdam
                    • 7
                    #249
                    I have same problem.
                    I have two dead open box s11
                    My serial cable and loader program work very well with first open box s11 and box get live back.
                    But second open box s11 not responding with Com port.
                    i tried many times by difference com port and with power supply of first open box to be sure about power supply, but not yet lucky
                    any help and information welcome .
                    Best regard
                    • stratosi
                      • Jan 2013
                      #250
                      skybox m3 raised
                      ok big big slugworth now works .. the problem was in the emulated serial usb-com. in practice using an older PC with built-in serial risen the skybox m3 and I'm happy for that.
                      I used eromupgrade with SKYBOX_3601HD_CMT_12092004D1.abs everything is broken down to the great .. Thanks to all and at Slugworth
                      • slugworth
                        • Nov 2011
                        • 1064
                        #251
                        in this case,older is better
                        • djmitch
                          • Jan 2013
                          My F3 box has died after an update too : (
                          • morisah
                            • Jan 2013
                            #253
                            Does any video guide for this tutorial? My skybox f3 going boot loop after load 100.
                            • morisah
                              • Jan 2013
                              #254
                              Originally posted by Lfcexiled
                              Just wanted to add, may be helpful....
                              My Skybox F3 got stuck in a loop on boot up whilst I was trying to update the channels from AJ's post so tried t update the firmware using the first post of this but kept getting the 'stb memory error' when using the eeprom in the package for download in the OP so had a look around the forum and found this post:
                              and that software worked a treat!
                              One point though, I found that if I tried to install newer firmware the box just stayed dead so went back to my original firmware and it was golden.
                              Thanks to the original posters for saving my box.
                              thanks dude..u rock. finally my skybox f3 work again.. im using rs232 custom made by myself.. work fine for the first time try... thank you man.
                              • amsterdam
                                • 7
                                #255
                                Who knows why open box s11 not responding with Com port.
                                Regard
