you must use openbox loader v2.0.0c and not some linux loader,since openbox isn't real linux.
Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
If the box is dead ...then reads the pages in this thread....it will explain how to bring the box back to life....Comment
I have just tested that link again & it's working fine.
It should download a .zip file which unpacks to a folder within a folder containing eromclient.abs, EromUpgrade.exe, flashburn.ini, LZMA.EXE, sdram.ini.
If you are using Internet Explorer as your browser, try using Firefox. IE has a known problem with corrupting some compressed files.Comment
Hi ive found a old laptop with a rs port, downloaded the upgrade tool and the firmware but when i browse and add the firmware i get a message saying wrong file..?Comment
hi to all got dead openbox ive red these instructions i still got problem with fw ie how do i find the right fw for my box to bring it back to lifeComment
Have you set your DHCP back to ON.
With most firmware I have tried, the default seems to be DHCP = OFF.Comment
