Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
  • slugworth
    • Nov 2011
    • 1064
    #481
    you must use openbox loader v2.0.0c and not some linux loader,since openbox isn't real linux.
    • riley35
      • 17
      #482
      hi guys I have be given 1 of these openbox s11 from a friend which seem to be dead I have downloaded the upgrade pvr 800 in the first link but all it gives me is a bin file could you please advise
      • P&D
        • May 2010
        • 2684
        #483
        If the box is dead ...then reads the pages in this thread....it will explain how to bring the box back to life....
        • Hadron
          • Nov 2012
          • 2102
          #484
          I have just tested that link again & it's working fine.
          It should download a .zip file which unpacks to a folder within a folder containing eromclient.abs, EromUpgrade.exe, flashburn.ini, LZMA.EXE, sdram.ini.
          If you are using Internet Explorer as your browser, try using Firefox. IE has a known problem with corrupting some compressed files.
          • Chalkywhite
            • 121
            #485
            Hi ive found a old laptop with a rs port, downloaded the upgrade tool and the firmware but when i browse and add the firmware i get a message saying wrong file..?
            • slugworth
              • Nov 2011
              • 1064
              #486
              downloaded the wrong firmware I guess
              • Chalkywhite
                • 121
                #487
                Was the same firmware I used the first time with the usb port...
                • slugworth
                  • Nov 2011
                  • 1064
                  #488
                  i've used the loader for years almost every day and never got that error unless it was with oddball firmware from another brand receiver.
                  • seangraves
                    • Sep 2012
                    • 275
                    #489
                    hi to all got dead openbox ive red these instructions i still got problem with fw ie how do i find the right fw for my box to bring it back to life
                    • slugworth
                      • Nov 2011
                      • 1064
                      #490
                      usually the oldest firmware you can find for a particular model is a good choice.
                      As an example,for the openbox s10 I use the may 2011 firmware,which was the 1st to have lan manager support.
                      • seangraves
                        • Sep 2012
                        • 275
                        #491
                        thanks mate i give it a go ps any chance link were to get it from
                        • DW190
                          • May 2012
                          • 1263
                          #492
                          Download / Software / Openbox S10/S11/S12_Shenzhen Yojia Technology Co., Ltd.
                          • Mojo007
                            • Oct 2013
                            • 12
                            #493
                            Hi, got my dead f5 back to life with the null cable, all seems fine except my magic ingredient is saying off, ive tried just about all i can with no luck, can someone help or point me in the right direction plz.
                            Thanks in advance
                            • Hadron
                              • Nov 2012
                              • 2102
                              #494
                              Thanks in advance
                              Have you set your DHCP back to ON.
                              With most firmware I have tried, the default seems to be DHCP = OFF.
                              • Mojo007
                                • Oct 2013
                                • 12
                                #495
                                Thanks Hadron, tried it both ways, also tried ingredient in another and its fine, tried factory reset, older firmware etc, no luck, all is great except the offline bit, i'm using ethernet so not like it could be wifi prob, anything else come to mind bud?
