skybox f3 wifi connection problem
My router has Authentication/encryption as wpa-psk...try selecting that and then you might get the option of wpa and wpa2 seperately in your security mode
This is how it looks like on my router:
Security
Broadcast Network Name:Yes
Allow New Devices:New stations are allowed (automatically)
Security Mode:WPA-PSK
WPA-PSK Preshared Key:xxxxxxx
WPA-PSK Encryption:AES
WPA-PSK Version:WPA2
Hope this helps..!!
attached pic of my router settings.Attached FilesComment
hi pal had some issues with my wifi to on the f3 and m3 ... try this firmware , works a treat for me , also has sky chanel list in perfect order built in ,
... not my work btw
Has anyone been able to get this working with a belkin sky router?
The only options I have are - WEP or WEP 802.11 or mix of WEP/WEP2. If I choose WEP or WEP 802.11 then my laptop loses wireless connection and it generates a 26-digit key. When I enter the 26 digit key into skybox it errors on invalid ASCII 5 or 13 message.Comment
Having problems getting wireless to work with BT broadband router. Changed settings to WEP2 only, still timing out. Maybe that Firmware will help but I'm on a MacBook Pro and the dongle is only for PCs. Anyone know how I can get firmware on to dongle via a Mac?Comment
I'm having the same "timeout" connection problem but i'm on vermin with a superhub.
in security i have these options
WPA Auto
WPA2-PSK[AES]
WPA-PSK[TKIP]
WPA/WPA2 Enterprise
WEP
Disable
I dont have the WPA2 on its own , also, even whwen i disable the security it still gives me "timeout". Anyone on vermin superhub and got it working ? mine is an offical mini dongle as well.Comment
Hi mate, I have the same hub and same problem as you. If I manage to sort the problem then I'll post the solution, can you do the same as well. ThanksI'm having the same "timeout" connection problem but i'm on vermin with a superhub.
WPA Auto
WPA2-PSK[AES]
WPA-PSK[TKIP]
WPA/WPA2 Enterprise
WEP
Disable
