Cwaite Sky Numbered Channel List **Discussion** Thread
  • Kudz
    • Jun 2014
    • 4
    #811
    Movie channels and sky sports 2 no signal can anyone let me know what frequency they on or if it will b updated channels list soon thanks.
    • martin035
      • Apr 2014
      • 1308
      #812
      Those channels haven't changed frequency recently, when was the last time you updated your channel list, if it's up to date (21/07/15) then it sounds like there's a problem with your setup. If this is the case then you're best starting a new thread as you'll get more help that way.
      • Kudz
        • Jun 2014
        • 4
        #813
        Jus checked I have 20/07/15 so that's still fine. I've jus checked sports 1 3 4 5 working exept 2 Nd all movies not working except showcase. I have f5s box and a sly +hd box both on at same time so I'm having that no signal issue but I don't knw why its happaning now had these two box on for the last year no problem with no signal. Only until yestaday.
        • cwaite
          • 360
          #814
          unplug the Sky HD box from the mains (do not just put it in standby) if the channels come back when the Sky HD box is unplugged then you need a no signal fix cable, if you have one already then it's sounds like it could be broken and you need a new one.
          If you need help installing channel guides or have a problem, take a look at my video guides
          https://www.youtube.com/playlist?lis...GHAAdpsKXqtadC
          • poyzy
            • Aug 2013
            • 31
            #815
            Hi Will there be an update with BT ultra HD ?
            • digicon
              • 8261
              #816
              Not in a Zillion Years this channel is exclusive to BT Broadband Infinty and BT TV customers only it is delivered through BT's own Broadband network.
              you wont be seeing this channel on satellite anytime soon
              • BrunoJ
                • Jul 2013
                • 141
                #817
                BT Ultra HD will be just another channel but in 4k instead of the HD 1080 !!
                • johnf1990
                  • Aug 2015
                  • 6
                  #818
                  does anyone know what ITV Granada HD transponder has changed to and does anyone know if bt sport extra channels 2-6 are available yet and on what transponder thanks
                  • digicon
                    • 8261
                    #819
                    BT Sport Extra 1 - 11082 H 22000
                    Extra 2-6 - 11344 H 27500
                    ITV Granada HD - 11097 V 23000
                    • lee11168
                      • Feb 2011
                      • 217
                      #820
                      when I scan this frequency I only get itv hd {central/London/meridian south} no Granada
                      • DW190
                        • May 2012
                        • 1263
                        #821
                        11052 23000 H
                        Comes up as ITV HD but it is Granada.
                        • breeville
                          • 69
                          #822
                          can anyone confirm if BT sports hd works with this list? having issues with AJ's list so might try this one. would like confirmation as once I overwrite my current list I cant go back and unsure what list is on it as it came with a v6 box
                          • joe516
                            • 1000
                            #823
                            yes m8 bt sports hd is ok
                            information given is to be used for educational purposes only
                            Don't Forget To Say Thanks If You Like My Post
                            IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
                            If It Ain't Broke Don't Fix It
                            • breeville
                              • 69
                              #824
                              didn't work with no adult list. invalid program. sd works but bt sports HD doesn't work.
                              • wxm14
                                • Jul 2014
                                • 63
                                #825
                                Just updated with the latest list,and none of my bt sport hd channels are working.
                                What I have noticed is that they all are showing the same frequency 11597/23000/V
                                Does anyone have the channels working,if so,can you post the frequency for each please
