Movie channels and sky sports 2 no signal can anyone let me know what frequency they on or if it will b updated channels list soon thanks.
Cwaite Sky Numbered Channel List **Discussion** Thread
Those channels haven't changed frequency recently, when was the last time you updated your channel list, if it's up to date (21/07/15) then it sounds like there's a problem with your setup. If this is the case then you're best starting a new thread as you'll get more help that way.Comment
Jus checked I have 20/07/15 so that's still fine. I've jus checked sports 1 3 4 5 working exept 2 Nd all movies not working except showcase. I have f5s box and a sly +hd box both on at same time so I'm having that no signal issue but I don't knw why its happaning now had these two box on for the last year no problem with no signal. Only until yestaday.Comment
unplug the Sky HD box from the mains (do not just put it in standby) if the channels come back when the Sky HD box is unplugged then you need a no signal fix cable, if you have one already then it's sounds like it could be broken and you need a new one.Jus checked I have 20/07/15 so that's still fine. I've jus checked sports 1 3 4 5 working exept 2 Nd all movies not working except showcase. I have f5s box and a sly +hd box both on at same time so I'm having that no signal issue but I don't knw why its happaning now had these two box on for the last year no problem with no signal. Only until yestaday.If you need help installing channel guides or have a problem, take a look at my video guides
https://www.youtube.com/playlist?lis...GHAAdpsKXqtadCComment
information given is to be used for educational purposes only
Don't Forget To Say Thanks If You Like My Post
IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
If It Ain't Broke Don't Fix ItComment
