Cwaite Sky Numbered Channel List **Discussion** Thread
  • cwaite
    • 360
    #886
    Originally posted by Someboody
    Hi CWaite,
    Just wanted to say a massive thank you for providing and maintaining this channel list. By far the best channel list for Openbox and I'm glad I came across this after seeing your website mentioned on the channel list installed on my box.
    There's a few very minor changes i'm not sure if you're aware of:
    Sky Channel 303 and 304 are Sky Movies Christmas and Sky Movies StarWars respectively
    Hope that helps
    Thanks for your kind words, At present as I don't have a great deal of time on my hands, I have decided to not change the channel names when these temporary channel name changes occur, I would rather use the little time I have to focus on permanent changes.
    If you need help installing channel guides or have a problem, take a look at my video guides
    https://www.youtube.com/playlist?lis...GHAAdpsKXqtadC
    • casper100
      • Jan 2013
      • 23
      #887
      After putting cwaites list on my openbox v8s sky sports 1 and 2 didn't work then i noticed that the service id was different to the ones on king of sat once i changed the id the channels worked again how come this is happening i never had any trouble with these lists before. i have noticed there are two service id's for these channels but the one on this list doesn't work.will it be like this for future lists?
      Sly sports1 - cwaites list service id - 4214 this doesn't work on my box
      king of sat has another id - 4221 this one works
      why is there different id's?
      • cwaite
        • 360
        #888
        Sky Sports is on quite a few different TP's and ID's (4214, 4216, 4221, 4611, 4914) not sure why yours is only working on 4221. 4214 seems to be the likely main Sly Sports 1 channel as it has the Narration (NAR) audio track on that ID, 4221 only has the main audio track and is likely to be a feed for rebroadcast. Can you see if channel 1141 and 1142 work, these are the Irish versions.
        If they don't work then I will add the SS1 SID 4221 and the SID for SS2 (if you can tell me what one works for you) to the test section.
        • casper100
          • Jan 2013
          • 23
          #889
          4221 and 4214 are on the same TP I don't understand why this is happening Yes the Irish versions work the id for sky sports 2 for me is 4222 also i have to change sky one to 4701
          • casper100
            • Jan 2013
            • 23
            #890
            sky sports 1 4221 and 4216 work 4214 doesn't
            sky sports 2 4222 and 1342 work 5505 doesn't
            sky one 4701 works 5718 doesn't
            sky sports news is a different TP than the one on your list i have to use 12266 with the id being 1325
            Until now i have never had any problem downloading the channel list on to my box i take it i will have to change them myself when new channel lists are available
            • cwaite
              • 360
              #891
              sky news is a different TP than the one on your list i have to use 12266 with the id being 1325
              Can you tell me what message you are getting on each of these channels that you are having problems with (i.e. No Signal, Scrambled, etc)
              • casper100
                • Jan 2013
                • 23
                #892
                scrambled comes up on all of them
                • cwaite
                  • 360
                  #893
                  Are you sure scrambled comes up on Sly News SD (Channel 501) this is Free to Air!
                  • tanviry
                    • 37
                    #894
                    cwaite, Mate with the latest update Channel 795 &TV HD has lost it's EPG. When u get a second can you have a look at this. Thanks.
                    • casper100
                      • Jan 2013
                      • 23
                      #895
                      Sorry sky sports news not sky news
                      • P&D
                        • May 2010
                        • 2684
                        #896
                        Sounds like you have a bad box or setup
                        I put the Cwaite's channel list on a brand new V8s box last night for a friend & every thing is running fine for the last 24 hours
                        on all the channels you are on about........
                        When was your setup last checked ?
                        also scrambled message has nothing to do with the channel list......its where you get your channels from or internet
                        But i guess you would know that looking at your other post's
                        • cwaite
                          • 360
                          #897
                          Are you able to get a free 24 hour test from someone else to see if this is a problem with your provider.
                          • cwaite
                            • 360
                            #898
                            This channel moved transponder on 2nd December so we might have to wait until whoever maintains the EPG to make amendments to get the listing back.
                            • casper100
                              • Jan 2013
                              • 23
                              #899
                              it's never done it before so i can't understand why it is now plus my dad has the same problem and he is on a different xxxx to me and a different internet provider as well
                              • cwaite
                                • 360
                                #900
                                It looks like your man has setup his system to AJ's Channel list, I am reluctant to change the channels on the main channel list as these SID's appear to be the main SID's used by Sly, and for the majority of people they seem to work without a problem, I have therefore added the frequencies and SID's as Alternatives and can be found on the following channel numbers
                                1260 Sly 1 (Alt)
                                1261 Sly Sports News HQ (Alt)
                                1262 Sly Sports 1 (Alt)
                                1263 Sly Sports 2 (Alt)
                                They are also added to the end of the Favourites, these Alternative channels will remain on Future Channel list updates.
                                If you can speak to your men and ask them to make adjustments to allow his magic to work on CWAITE's list as well as AJ's then that would help a great deal.
