history hd and net geo hd gone and more ** See First Post for Updates **
Just noticed the movie ScFi/HorHD is not working.
Can anyone else confirm?
Channels gone so far..
Sky Disney HD
Sky SciFi/horror HD
Sky Premier HD
Sky One HD
Sky Arts 1 HD
Sky Arts 2 HD
National Geographic HD
National Geographic Wild HD
History HD
Crime & Investigation HD
Sky Living HD
Sky Atlantic HD
A friend recommended that I should get a diseqc switch and a bigger 80cm dish.. it would allow hotbird to be viewed..would that be a good workaround for hd channels?
i found this on an other website looks like the new updates sly have is spreadinglike wildfire , im not sure how true this all is but i thought to post this message
" The new pairing is based on the hardware pairing chip, that is already broken as we all seen on the past 18 months hardware pairing emulation for Conax was released, as well as other systems. There is few studies also published about this hack. The same chip and code is doing this hardware pairing you are talking about as well as the Conax or other CAS.
I was also told that a new box is coming (not linux) from the usual people at the origin of the working "3 months cards" such as K3, Knot2.x, Millenium, Abracadabra, Omnia, Opos, that is emulating all the hardware pairing for the various CAS... all this based on a hacked ST chipset.
So the hardware pairing is broken, it now seems to fall on the hands of the old good "3 months pirate card" german mafia suppliers, but it would probably soon go to Linux boxes as piracy of pirate products is the usual way... (due to very bad quality and full of bugs software, easy to extract / hack, for sure more easily than the original product from CAS).
by the sounds of it the pairing system that sly have used it may be hackable, but u may need a new box ? .
when i seen this message on another website i thought someone on here may know what this guy is talking about ?
In all fairness if sly have put update through all boxes then there will be a workaround, like xbox 360 for chipped games they said the slim wouldnt be able to be hacked they thought wrong when the guys got on to it and then bang then found a way around it same has this they will find a way around it may not be weeks or months but someone will fix it , has the counter measures have been put there , theres aload of ppl working on a hack has we speak
If true it means a fix is on the way but don't hold your breath because any fix is likely to stay well underground for a long time to come. Lessons will have been learned and the number of blatant ads in the last 12 to 18 months or so on the likes of fleabay openly promoting stealing pay tv has resulted in a sharp demise of the anonymity of what is possible with a bit of know how.
It may be true or it may not be true. As always there are rumours a plenty but in my opinion of you want to be sure you can watch sat tv for a long time to come by a motor or learn to set up a fixed dish multi sat system. With patience, a good chunk of common sense and a lot of good tutorials with support from forum members anything is possible.
