history hd and net geo hd gone and more ** See First Post for Updates **
ok
this is what has happen sky Italy was able to stop hd around 8 years ago now, xxx have done the same sd channels are safe for some time but there is no fix for hd when fully implemented sd is still running with sky italer so all stop worrying and enjoy .but remember hd could go any time
bt sports 1 and 2 hd have moved frequency so not to be confused with the current changes a simple sat scan or transponder scan will bring these 2 back
thought i would mention this as some people will think these 2 have gone the same way
boxnation also has moved frequency
It's not an ecm encryption change I'ts Changing the HD format to Mpeg5
So until CS boxes come out that can cope with Mpeg5 the HD channels will be gone but all SD wile be fine.
I have an issue where all my channels are working fine... but when it scrambles it don't return back and I have always have to switch off and on the receiver to make it work.... is there problem with my set up or box?
bull-sh1t, but cue the skybox brigade googling for an mpeg5 skybox now
Sky are changing the HD text format to Mheg 5 m8 ,not changing the HD video format to Mpeg5.
will have to think about a motorised system as live in a non vermin area, got dish on a KT bracket already though would probably want two dish's so the other half can still watch her soaps while I browse the satalites
