Dreambox streaming to internet,it was never easy like this
  • micko
    • 24
    #61
    Well hib there can anyone help i am trying to flash dream box 500-c 1.1. having trouble to unzip the files i have how do i do it please help
    • benjaminok
      OK
      Originally posted by mfaraj57
      again to demonstrate the idea of the program
      live classical music from my dreambox500 at this link
      radio clasica at hotbird
      mms://waed.dvrdns.org:1234
      just enter in windows media player and enjoy
      this link valid between 6-9 gmt
      yes mate!
      It worked just fine, no problems listning to the stream here in Denmark.
      Still working on the setup, will post a link for testing later.
      • Dedes
        • 19
        #63
        Hi mfaraj57
        I am still not able to put the software working.
        On the setting of the streamer when I click on the last ? to test dynamic dns and port forwading I get an error saying that my dns was not created or updated. I have used my static IP and the result was the same.
        So maybe I have a problem creating this dns. Could you explain with some dettail how to created this dns?
        I have created one following all the pictures that I saw on the Tunisian forum but I am not sure if I did it OK.
        Dedes
        PS - an update: If on the streamer server port settings I enter 1234 I get the error I mentioned but if I enter port 5678 it says it is OK
        • mfaraj57
          • 557
          #64
          Originally posted by Dedes
          Hi mfaraj57
          On the setting of the streamer when I click on the last ? to test dynamic dns and port forwading I get an error saying that my dns was not created or updated. I have used my static IP and the result was the same.Well hib there can anyone help i am trying to flash dream box 500-c 1.1. having trouble to unzip the files i have how do i do it please help
          Dedes
          Hi dedes
          you do not need dns address because you have static ip
          instead filling dns address fill your static ip
          you do not have to test it ,but if you want from
          start-run-cmd
          write this
          ping dnsaddress
          if it is ok it will give something like this
          if not
          the dns address is created but not updated
          • mfaraj57
            • 557
            #65
            live stream of radio 3 radio channel on hotbird from dm500
            upload speed(90kb/s) and transfer upload speed 8k b/s
            just enter this address mms://waed.dvrdns.org:1234
            from 3-4 GMT sunday
            • mfaraj57
              • 557
              #66
              Originally posted by .: JaCkPoT :.
              mfaraj can you just stream some show sports for me and PM me the link please! only for 5mins
              just wanna see how showsports is!
              now showsport from dm800 at
              from 6:30 -7:30 GMT
              i will not promise to get clear continuous video because streaming with low upload speed(80 kb/s and upload transfer speed 8 kb/s with 512 kb/s adsl speed
              but imagine with 700 kb/s upload speed(4 mg/s adsl speed),the quality of video stream will be
              • mfaraj57
                • 557
                #67
                Hi there
                for all have faced problems with the program , port 1234 and port forwarding
                please use VLC download version .99 and avoid using version 1.0.0
                i advice using port 1234 because it is the vlc default
                vlc version .99 download
                • mfaraj57
                  • 557
                  #68
                  Hi mfaraj57
                  Dedes
                  hi
                  check version of vlc you are using
                  last vlc version 1.0.0 is not compatible with program
                  use vlc .99 and everything will be ok
                  • gurr
                    #69
                    Hello everybody!
                    First of all i want to say that im a big fan of ur work mfaraj57! Keep up the good work!
                    I just bumped into this thread and i downloaded and installed your tunisia-sat dreambox player and streamer5.0 ..
                    And I actually managed to stream! Locally and on the internet ... I own a Dreambox 500 with Gemini, thus i get the same blurry screen as in post #11, by mfaraj57, in this thread ...
                    I hope this can be fixed in the future
                    Once again mfaraj57 keep up the good work!
                    • mfaraj57
                      • 557
                      #70
                      Originally posted by gurr
                      Hello everybody!
                      thanks Gurr
                      quality of video streaming depends in two things
                      1-Type of dreambox and the image installed on it
                      Pli-jade is the best for internet and local streaming while Gemini is the worst
                      Enigma 2 dreamboxes(dm800,dm8000,dm7025) are better regarding streaming than enigma1 dreamboxes(dm500,dm600....)
                      2- Internet speed
                      The program does transcoding(compression and conversion) for dreambox stream before restreaming to internet
                      this process transcoding downgrades the quality of the video stream,as much as you did compression the qaulity get worse
                      in program settings there are three choices ,according to your internet speed select your option
                      low upload speed -gives the worst stream
                      medium upload speed gives better streaming
                      high internet speed gives the best video stream quality
                      • mark1832
                        • 32
                        #71
                        For all the users of this fantastic forum that cant make the mfaraj software work, please search for " Dreambox Streaming Over the Internet Using Orb.pdf " and make sure that with a PLI image to not to input all string but just the http://192.168.x.xxx:31344 without any subsequent stream info of the channel.
                        If you dont understand send me a pm with your landline,skype,msn and i will help you... I will not be prepared to write 100's email/messages just want to speak and look at your pc with Teamviewer. Italian and English speaking only
                        • mfaraj57
                          • 557
                          #72
                          Hi
                          Yes I am sure about having a static IP - I pay more because of that!!
                          I have seen the internet streams adress but they come and go very quickly. I am not able to read them. Is there a way to keep them stick for me to copy and paste it?
                          And I have port 1234 forward to my PC IP - DHCP IP - but I am not 100% sure it's working because I have tried the port scanner and it says that port is closed.
                          PS - I was able to get the stream adress and I have used both the xxx.dyndns.org account that I have created and my statci IP but none of them work.
                          Hi
                          This problem because the program is incompatible with version vlc 1.0.0
                          installation of vlc .99 will solve the problem
                          just open port 1234 or what port you like and you do not have to check by online internet checkening tool or other method because most of them will give false results
                          just go to program and start streaming
                          • mfaraj57
                            • 557
                            #73
                            Originally posted by dowlinr
                            Didn't work for me, either locally or internet.
                            hi
                            just install vlc 0.99 and the program will work perfectly
                            • mfaraj57
                              • 557
                              #74
                              Originally posted by Ruddyrum
                              local works, internet doesnt!
                              However, if i manually transcode the stream from my dreambox to my PC using VLC, i can watch it via the internet with ease! If mfaraj57's new release will not sort the issue, i will post a quick guide!
                              Obviously it will not come in a nice program, and will require some manual inputs/effort, however it works 100%
                              with regards to the question about ports being forwarded, check their status with PFPortChecker
                              The explanation for this
                              the program is designed to work with version .99 and incompatibe with vlc 1.0.0
                              all the problems will be solved when install vlc .99
                              • mfaraj57
                                • 557
                                #75
                                Enjoy classical music from my dm500 live stream from classical radio channel-orbit arabsat
                                for 1 hr from 11-12 GMT
