Dreambox streaming to internet,it was never easy like this
HiHi mfaraj57,
Can you please help me with a strange problem
when I choose the advance option for upload profile and press restream , the address which results starts with MMSH or HTTP, I copy the full address and paste it in url of windows media player, the player rejects both addresses that start with MMSH and HTTP.
please help me how to solve this problem
Thank you in advance
These formats to be used only with vlc player
to play mmsh with wmp just delete h and put mms://xxx.xxx:1234 in windows media playerComment
Did what you suggested and got a response from windows media player :
windows media player can not play the file because of network error> server might not be available > verify you are connected to network and that proxy settings are correct>
am connected to network and proxy settings are correct
I even copied the mmsh address to vlc player but again failed and I got the following response (VLC is unable to open the MRL 'mmsh://xxxxxxx.dyndns.biz:1234'. Check the log for details.)
Am really desperate . Sorry to bother you but any further suggestion
best regardsComment
Hi Nabbat and sorry for delay in response because net problemHi,
best regards
from these error messages no streaming occur
did vlc pop up when streaming and playing stream
check your port
check you dns address
use preset values instead of advanced from settingsComment
hi mfaraj57,
i tried to set this apps to my nokia n97 but i can not find the compatible core player.needs your expertise.please help. and thanks in advance.
if port 1234 opened and forwared well then streaming is Inevitable
you can check for that by portchecker tool,presents in tools folder
what vlc version you are using
did vlc pop up during streaming and play stream
what about preview buttons did they show anythingComment
im using port 10004 and 5678 checked and are open
vlc version 1.0.5
only one tiem i can view the streaming image but wend restart aplication never see it againg
i need to install other plug in on DM800 to get streaming?
recomended codec for pc ?Last edited by poroto40; 22 May, 2010, 10:50.Comment
no need for any plugin for dreambox regardless its model
no special codec needed for pc also
you should try different codec from settings
low,medium or high upload profile or even from advanced section
if you can take picture during streaming it will be helpfulComment
let my card update tier and i will try again thanks for allComment
