Dreambox streaming to internet,it was never easy like this
  • saintomer
    • Aug 2009
    • 13
    #181
    Hi XtraStrong why not try it for yourself and see if it 's stable enough for you ?
    saintomer.
    • rruunneerr
      • 62
      #182
      Hi mfaraj57,
      please keep up the good work as you are nearly there with this program.
      Using the original 5.0 version, i find it starts streaming fine for 4-5 mins then it says 'stopped encoding' but still looks like it is streaming. What can i do to stop it saying this all the time as this really my only issue now?
      My PC is dual processor 4gig ram as well as my laptop, both the same result.
      Also when i stream to a friend, he can see my stream for about 30secs then it cuts out and has to rebuff, this is strange as he has 8mb broadband connection. I told him to use vlc which had little improvement, any suggestion to make his computer stream receive a better stream?
      Kev.
      • saintomer
        • Aug 2009
        • 13
        #183
        out of interest rruunneerr what OS are you using (you and your m8's) ive had this running on on vista but only really been testing with xp so far ...
        saintomer.
        • mfaraj57
          • 557
          #184
          Originally posted by rruunneerr
          Hi mfaraj57,
          Kev.
          Hi again
          I have streamed from my dreambox today from the last update exe for 5 hrs with very low upload speed without stopping and without any problem and from dreambox 500 which should be less stable than dm800
          second you can watch someone streaming from ksa since moring without stopping and you can see at my site
          sometimes i face streaming strange behavior but not always i think the matter related to interactions between different codecs installed in pc,as you know dealing with graphics in pc is complicated mattar and you have to expect many probelms
          last update work for me good and very stable while with you gives problems because we have different enviroments
          i revert back to most stable one 5 and facing some problems with mobile version and i have surprized the stable version gave me same problem
          i think the mattar related to codecs installed and to cpu and to the applications opened
          rebooting pc and close all application may solve all the problem
          It is important to use version vlc .99
          you can test the program on other computers and see
          • saintomer
            • Aug 2009
            • 13
            #185
            Hi mfaraj57.
            just tried your mysite and media player is timing out so assume it's off now ?
            saintomer
            • mfaraj57
              • 557
              #186
              Originally posted by saintomer
              Hi mfaraj57.
              saintomer
              streaming is not from me just host dns address from saudia arabia
              if stopped may be the streamer went to spleep because it is late this area but now it is working and i am far enough from streamer
              • rruunneerr
                • 62
                #187
                both systems are running XP, but my friend is using the latest VLC player 1.1.
                WIll this be is problem?
                Also Mfaraj57, once again many thanks for your speedy reply and help.
                Cheers,
                Kev.
                • notej
                  Originally posted by mfaraj57
                  hi
                  just for test just extract the exe to program folder no need fo setup
                  more flexibility in chosing upload speed and more advanced options
                  works fine for me
                  • mfaraj57
                    • 557
                    #189
                    There is second program dreambox vlc streamer by Tunisiasat and nearly does the same jop as dreambox player and web streamer
                    both programs are using same method to stream and favor not for me neither for vlc streamer it is for vlc and its ability to transcode
                    so result and quality of streaming are the same in two programs
                    for whom facing problems with my program i advice to use the other, both do same jop and similar streaming quality although my program simpler and has more functions
                    • saintomer
                      • Aug 2009
                      • 13
                      #190
                      Hi Mfaraj57,
                      just wondered if youve made any further progress with your program ?
                      I've tried the vlc streamer posted above but have found the streaming
                      not as good as from your program, it streams ok for a while then gets
                      jerky before streaming ok again and it continues like this where as
                      your program runs very smoothly
                      saintomer
                      • mfaraj57
                        • 557
                        #191
                        Hi Mfaraj57,
                        saintomer
                        Hi saintomer
                        I put the above program after it is mentioned by Ian in the other forum
                        really i didnot find it very helpful and usualy launchs vlc player to do streaming
                        The quality of streaming either in my program or dreambox vlc streamer or vlc player itself are the same because all follow the same mechanism
                        When i noticed the streaming quality in my program is bad and chopy i do streaming the same deambox channel by vlc player and gave me the same poor quality
                        so the streaming quality depends upon various codecs we used and ability of cpu to handle the transcoding process
                        VlC is poor streamer but the simple one available,i hope in next development of windows media player 12 that microsoft will solve the streaming issue by windows media player 12
                        Regarding my program i have done some changes regarding streaming to mobile and to fix language priority
                        • dale094
                          • Mar 2009
                          • 41
                          #192
                          mfarag57
                          can you help i have done everything to your instructions and all seems fine when streaming from preview internet and locally
                          but i cant seem to get anybody outside my network to recieve streaming through mms://*****.dyndns.org:1234
                          i have account and dyndns updater says updated can you help.
                          • saintomer
                            • Aug 2009
                            • 13
                            #193
                            Hi mfaraj57,
                            ok i've changed scale to 0.75 and this has stopped the chopyness
                            current settings are;
                            asf.
                            div3.
                            3072.
                            0.75
                            mp3
                            128
                            2 channel
                            and looking much better.
                            St.O
                            • mfaraj57
                              • 557
                              #194
                              Originally posted by dale094
                              mfarag57
                              if you can preview locally and by internet the logic thing that others far should receive the stream
                              if you do not mind pm the dns address
                              • mfaraj57
                                • 557
                                #195
                                Hi mfaraj57,
                                asf.
                                div3.
                                3072.
                                0.75
                                mp3
                                128
                                2 channel
                                St.O
                                I think it is good compination but 3072 is high vbitrate and you could not stream this outside with other side download problems
