Dreambox streaming to internet,it was never easy like this
  • dale094
    • Mar 2009
    • 41
    #196
    have sent u pm with my dns address
    thanks mfarage57
    • ian1095
      • Aug 2009
      • 27
      #197
      Originally posted by saintomer
      Hi mfaraj57,
      ok i've changed scale to 0.75 and this has stopped the chopyness
      current settings are;
      asf.
      div3.
      3072.
      0.75
      mp3
      128
      2 channel
      and looking much better.
      St.O
      saintomer,
      theres no way you can stream these settings to your WAN.
      these settings will give you the best result on your home pc,but this is because,although it is going out through WAN,its not going very far to get back to you.
      anyone you stream this too such as friends or family probably wont even be able to lock onto the stream for more than a couple of seconds.
      unless your on T1 or T3 this will never work,i dont care how good your upload is,you are trying to stream far too much information for your upload capabilities.ian.
      • mfaraj57
        • 557
        #198
        thanks mfarage57
        The address doesnot work please test port 1234 by port checker
        dns address seems to bo good
        Port checker
        • ian1095
          • Aug 2009
          • 27
          #199
          ive been trying all day to get H264 and MP4V to work and i just cant.ive tried every FFDshow codec there is and every splitter and solution i could find on the net,it just wont work.anyone know why this is?
          is this a VLC problem?
          can VLC transcode and stream with these codecs?
          ian.
          • dale094
            • Mar 2009
            • 41
            #200
            mfaraj57
            got my port forward working now streaming from my laptop
            no buffer overun picture stable on 400kbps upload
            many thanls
            • jigga_man411
              • Aug 2009
              #201
              trying to stream
              could someone make a video of the whole procedure from start to finish with the hooking up of the cables, the type of cable to use,where to put it in the router or modem or hub. Which program to download and where to get it from .Ya know what i mean ,the whole operation.I think it will help alot of people to understand.thanks
              and i would be very greatful cause i download this ting about 5 times and can't get it to work yet
              ps ;explain how to open de ports would be great also
              • mfaraj57
                • 557
                #202
                ian.
                Hi Ian
                sure it does stream with these codecs and the preferable codec for vlc is H264 and the most stable one and the next is mp4v
                for streaming with these codecs good compination is necessary as example no stream with encapsulation ASF/wmv with these codec
                • mfaraj57
                  • 557
                  #203
                  if you follow this discussion from start you will find the solution for any problem
                  Very simple to use the program just choose channel and hit start streaming
                  but before that you should assign dns dynamic address for you and open and forward port 1234 to your pc ip
                  that,all
                  regards
                  • ian1095
                    • Aug 2009
                    • 27
                    #204
                    Hi Mfaraj57
                    it doesnt matter what encapsulation method i use,i cannot get a picture on WMP when using the H264 and mp4v codecs.the audio is fine,but the picture just wont show.i spent all day yesterday installing and uninstalling codecs on my pc,each of which claimed would get me a picture in WMP when recieving a H264 stream,but none of them worked.even the splitters didnt work.
                    are you able to view a stream on your pc using WMP that has been sent to you via VLC and your program when its using the H264 codec?
                    im really beging to think that VLC cannot stream this codec.ian.
                    • mfaraj57
                      • 557
                      #205
                      Hi Mfaraj57
                      Hi Ian
                      you will not see picture from stream(h264 or mp4v) by windows media player you have to use vlc itself to play the stream
                      wmp does not have the specific plugins for these codecs to play
                      • ian1095
                        • Aug 2009
                        • 27
                        #206
                        thank you my friend.
                        but the crash you have displayed doesnt happen when streaming with VLC 1.0.1
                        i wish i had asked before wasting a whole day trying plugins and codecs that claimed they would get WMP to play the stream.
                        the only problem i now face is that for some reason VLC wont open the stream when i type in mms://my DNS:1234 on the client pc like what WMP does.
                        VLC just states that it was unable to open the address.
                        is there another player for the client pc that can display a stream thats using H264?
                        i tried winamp pro,but that wont display a picture either,just the audio like WMP.ian.
                        • mfaraj57
                          • 557
                          #207
                          to say first mms protocol will not accept h264 codec so you should use http protocol .with h264 with mms use only wmv2 or div3
                          to play mms by vlc for reason i do not know use mmsh instead of mms like picture
                          • mfaraj57
                            • 557
                            #208
                            Yes vlc player 1.0.0 and 1.0.1 can play h264 while vlc .99 usually crashs
                            i think realplayer can play the stream in any format
                            • saintomer
                              • Aug 2009
                              • 13
                              #209
                              Just to confirm what I've posted on dudez,
                              got h264 with mp4a and mp4v with mp4a streaming to vlc client
                              can get mp4v to play on media player classic but no audio
                              no h264 on media player classic
                              using dreambox vlc streamer v1.1 and vlc 1.0.1
                              got a vlc could not open the address error when used with dream2webstreamer 1.0.0
                              saintomer
                              • ian1095
                                • Aug 2009
                                • 27
                                #210
                                me too now,just to copy ,all thanks to saintomers and mfaraj57's help.
                                the h264 codec does make a big difference,so its well worth getting this working.im also using the VLC streamer 1.1 and VLC 1.0.1.
                                no go with real player either.ian.
