SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • tony2803
    • 266
    #226
    no itv 1+1
    just went through file with dreamedit and cannot find itv1+1
    can this channel be added to this file..thanks.
    • SGTFlipFlop
      • Sep 2009
      • 1002
      #227
      Check after The Universal Channel
      • bigoz
        • 105
        #228
        i've tried to import the latest flip flop enigma 2 files via dreamboxedit and get them over no problem, but under the Sky HD bouquet i can only see the red markers - there's no HD channels - any ideas?
        • markshore
          • Oct 2010
          • 120
          #229
          Radio Picons
          Hi thanks for the updates, have just started using the picons as well, would it be possible to include the radio picons sometime.
          Regards
          Mark
          • SGTFlipFlop
            • Sep 2009
            • 1002
            #230
            Regards
            Mark
            Find me source files for each channel and I'll make them
            • SGTFlipFlop
              • Sep 2009
              • 1002
              #231
              I've found some I'll do as many as possible and I'll do a channel update later tonight
              • SGTFlipFlop
                • Sep 2009
                • 1002
                #232
                Radio Picons complete, Will test in a minute
                • SGTFlipFlop
                  • Sep 2009
                  • 1002
                  #233
                  Do radio picons work? Cant seem to get them working
                  • SGTFlipFlop
                    • Sep 2009
                    • 1002
                    #234
                    Someone test them for me
                    • SGTFlipFlop
                      • Sep 2009
                      • 1002
                      #235
                      Here is the latest update
                      DreamboxEdit 4.0.1.2 Used (Recommended) Guide Here
                      Enigma 1 = Dreambox 500, 600, 7025
                      Enigma 2 = Dreambox 800, 8000, 500 HD
                      Updates: 26th January 2011
                      Bouquet Updates
                      Channel One (New Frequency)
                      Challenge +1 (New Frequency)
                      LivingIt +1 (New Frequency)
                      Living Ireland (New Frequency)
                      PTV Prime (New Frequency)
                      Removed Channels
                      Channel One
                      Challenge +1
                      LivingIt +1
                      Living Ireland
                      PTV Prime
                      Picons
                      Radio Bouquets all done, I can't get them too show on Dreambox, Anyone instruct me how to get them to show?
                      I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
                      ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
                      Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself
                      Use any FTP client, DCC for example, to transfer the picon directory
                      to one of the following paths on Flash, HDD, CF or USB respectively:
                      /usr/share/enigma2
                      NOT recommended, because of limited capacity of the flash memory
                      /media/hdd
                      HDD will keep running indefinitely and may affect image performance
                      /media/cf
                      Recommended if CF available and successfully mounted (8000/800)
                      /media/usb
                      Recommended if USB available and successfully mounted (8000/800)
                      Picon will display immediately on zapping, no further setup required!
                      Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
                      Please keep this thread clean, Use the Thanks button rather than posting on the thread
                      • markshore
                        • Oct 2010
                        • 120
                        #236
                        Radio Picons
                        Hi tested one this morning Absolute radio classic rock same id as the old one i was using, works fine.
                        Running DM500HD with Neverland PP 2.2 image stored in flash as could never get them to work from the HDD.
                        Regards
                        Mark
                        • jondalor
                          • 37
                          #237
                          great work, thanks a lot.
                          unfortunatly i seem to be missing quite a few channels, i,m using a db500 with nabilio v08 maxvar image.
                          i'm not seeing boomerang, cartoon network, sky arts,home and good food to name a few, i,ve rescanned and even the listings in all services do not show these channels. sat signal is fine as they show on sky box.
                          anyone any ideas?
                          • SGTFlipFlop
                            • Sep 2009
                            • 1002
                            #238
                            anyone any ideas?
                            When scanning change the option - Clear Before Scan - Choose Yes
                            • jondalor
                              • 37
                              #239
                              i don't have that option(as far as i can see) icould delete the transponders one by one, would that be a good idea? or is there a clear list option hidden on this image?
                              • BlueBox
                                • 573
                                #240
                                @ SGT i have spent some time moving some channels around mostly asian ones
                                just wanted to know if i update to your lastest file will i lose all the settings
                                anyone out there using 500HD with Newenigma2 need help channel scanning
                                DreamBox 500HD NewEnigma2
