SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • markshore
    • Oct 2010
    • 120
    #241
    Radio Picons
    Hi thanks for the update for the radio, yours seem to be the best and most complete picons, looked at some from silverfox before yours on this forum but has a few errors etc.
    Would it be possible to add
    RCR (VOT) Radio
    TWR Radio
    KHUSHKHABRI Radio
    Then every radio channel is complete with picon.
    Regards
    Mark
    • RuberDuck
      • 1724
      #242
      Originally posted by BlueBox
      @ SGT i have spent some time moving some channels around mostly asian ones
      just wanted to know if i update to your lastest file will i lose all the settings
      anyone out there using 500HD with Newenigma2 need help channel scanning
      yes you will loose all your alterations as the bouquet you load onto the box totally replaces what's already there.
      • RuberDuck
        • 1724
        #243
        RCR (VOT) Radio
        TWR Radio
        KHUSHKHABRI Radio
        Regards
        Mark
        tell me what errors your referring to and i'll make silverfox aware.
        • markshore
          • Oct 2010
          • 120
          #244
          Hi BBCi has no picons, mtvn Hd Picon showing on sky box office Hd, plus a few others if you install the picons I was talking about, just flick through all the channels and there associated picons and you will see.
          Regards
          Mark
          • RuberDuck
            • 1724
            #245
            Regards
            Mark
            i dont use picons i think there a gimmick and a waste of time, i will pass on your findings to silverfox however.
            • SGTFlipFlop
              • Sep 2009
              • 1002
              #246
              I deleted all the Picons yesterday and re-did every single one, Took me the whole day.
              There are some that I cannot find as the ones you mentioned in the Radio bouquet, Cannot find a source file to make a Picon from.
              Done a few changes to the Bouquet aswell that has impressed me so far, Big update of channels due on the 1st Feb so I'll just wait until then to release the lot
              • SGTFlipFlop
                • Sep 2009
                • 1002
                #247
                Here are the Picons, All redone from scratch and correctly mapped
                Seem some people put them on other forums without saying who created them, Not nice
                Also 1 more thing to the guy who is selling them on eBay for 99p Haha
                • bigoz
                  • 105
                  #248
                  good work FlipFlop - this should really be a sticky in my opinion!!!!!
                  by the way when trying to set up the picons, what is this option? and how do i set it up?
                  "/media/cf
                  Recommended if CF available and successfully mounted (8000/800)"
                  • SGTFlipFlop
                    • Sep 2009
                    • 1002
                    #249
                    Here is the latest update
                    DreamboxEdit 4.0.1.2 Used (Recommended) Guide Here
                    Enigma 1 = Dreambox 500, 600, 7025
                    Enigma 2 = Dreambox 800, 8000, 500 HD
                    Updates: 29th January 2011
                    Bouquet Updates
                    Sky Atlantic (New Channel, Added to Testing EPG)
                    Sky Atlantic HD (New Channel, Added to Testing EPG)
                    Removed Channels
                    Picons
                    Every single one remade from scratch, All my own work
                    With help from someone I have added an option so the channels wont change name from now on, They will stay how they are listed in the Bouquet.
                    I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
                    ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
                    Also added Picons for Sky UK ,
                    All correctly mapped and a few obscure ones missing only
                    Use any FTP client, DCC for example, to transfer the picon directory to
                    one of the following paths on Flash, HDD, CF or USB respectively:
                    /usr/share/enigma2
                    NOT recommended, because of limited capacity of the flash memory
                    /media/hdd
                    HDD will keep running indefinitely and may affect image performance
                    /media/cf
                    /media/usb
                    Recommended if USB available and successfully mounted (8000/800)
                    Picon will display immediately on zapping, no further setup required!
                    Always remove old picons from Dreambox before uploading new ones,
                    Sometimes they don't overwrite correctly
                    Please keep this thread clean, Use the Thanks button rather than posting on the thread
                    • smirnoff_rules
                      • 8603
                      #250
                      can u make a Enigma1 allsats , l have tried to convert but no luck
                      • SGTFlipFlop
                        • Sep 2009
                        • 1002
                        #251
                        Open E2 all sats in DBE click tools and then choose the bottom option 'Toggle between version 2 & 4 settings' and then save too a new folder
                        • smirnoff_rules
                          • 8603
                          #252
                          ok l'll try again cheers
                          • etch
                            • 70
                            #253
                            Bouquets
                            Hi Sgt,
                            I am having a problem sending the bouquets to my Dm800. They see to load ok but when i go onto favorites the bouquets are not there? I have tried many times but i cant get the bouquets to show.
                            What am i doing wrong baring in mind that i have done this successfully for months?
                            • BlueBox
                              • 573
                              #254
                              Originally posted by etch
                              Hi Sgt,
                              Are you sure you are clicking "Send Files to Dreambox" and not Reload setting on dreambox?
                              DreamBox 500HD NewEnigma2
                              • etch
                                • 70
                                #255
                                Yes, i am sending the files to dreambox first as i always have in the past. I just cant understand why it is not working? Whenever i send the bouquets to the box and check, all i am getting is an empty favorites folder???
