SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • SGTFlipFlop
    • Sep 2009
    • 1002
    #316
    Tried sending them via Dreamset?
    • etch
      • 70
      #317
      Thanks for the fast response.
      yes only just tried but again the bouquets do not show, however it does not alter the tuner configuration phew....
      I did ftp my box to make sure that the files are going to the correct place and have noticed that all the bouquet files have a '0' file size despite them having between 1 and 5 KB before i send them over. I have tried just to ftp them over but that too is not working.
      • SGTFlipFlop
        • Sep 2009
        • 1002
        #318
        Here is the latest update
        DreamboxEdit 4.0.1.2 Used (Recommended) Guide Here
        Enigma 1 = Dreambox 500, 600, 7025
        Enigma 2 = Dreambox 800, 8000, 500 HD
        Updates: 9th February 2011
        Bouquet Updates
        Clubland TV (New Frequency)
        Rush HD (New Frequency)
        Removed Channels
        Clubland TV
        Rush HD
        Picons
        Fixed 2 channels above
        I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
        ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
        Also added Picons for Sky UK ,
        All correctly mapped and a few obscure ones missing only
        Use any FTP client, DCC for example, to transfer the picon directory to
        one of the following paths on Flash, HDD, CF or USB respectively:
        /usr/share/enigma2
        NOT recommended, because of limited capacity of the flash memory
        /media/hdd
        HDD will keep running indefinitely and may affect image performance
        /media/cf
        Recommended if CF available and successfully mounted (8000/800)
        /media/usb
        Recommended if USB available and successfully mounted (8000/800)
        Picon will display immediately on zapping, no further setup required!
        Always remove old picons from Dreambox before uploading new ones,
        Sometimes they don't overwrite correctly
        Please keep this thread clean, Use the Thanks button rather than posting on the thread
        • bannthemman
          • Feb 2011
          • 16
          #319
          Hi sgt flip flop
          ive a dm500s what im wanting to know is if its possible to put the enigma 2 multi file onto my unit because im looking to go the euro route with motorised dish.
          i use dreambox edit to put your files onto my dreambox
          • SGTFlipFlop
            • Sep 2009
            • 1002
            #320
            Originally posted by bannthemman
            Hi sgt flip flop
            bannthemman not possible mate, It needs to be converted and takes a long time for me but if you have the time to do yourself
            Delete every HD channel manually change version to 2 then save in a new folder, Voila
            • bannthemman
              • Feb 2011
              • 16
              #321
              Could you give me a brief example of how to do this mate coz i dont understand the change to version 2 bit
              • wizard55
                • Jul 2010
                • 7
                #322
                Movies
                Thanks for all your hard work Sgtflipflop.
                Is there of defaulting the audio channels on the sky movies to english instead of that annoying Nar.
                I have to reset everytime i update bouquets. Is this correct or I doing something wrong.
                • mufctommo
                  • Dec 2010
                  • 21
                  #323
                  sky living
                  hi there i've just updated my dm500s with the latest bouquet big thanx to the sgt but i dont seem to have sky living,sky living +1 and sky livingit i have rescanned my box and they are in all channels but just black screen no pic hope somebody can help cheers
                  • markshore
                    • Oct 2010
                    • 120
                    #324
                    Hi SGT thanks for the regular updates to the bouquets, i have been using some laminated picons made by Lichter which are very nice the problem is that when i use them with your bouquet bbci, box office etc do not show. If i use the other providers bouquet and picons all ok, if i use both of yours all ok but cannot seem to mix and match any ideas as to why.
                    Regards
                    Mark
                    • markshore
                      • Oct 2010
                      • 120
                      #325
                      Hi Wizard55 i had to set my dreambox to ac3 as default audio under av settings as i used to have the same problem.
                      Regards
                      Mark
                      • SGTFlipFlop
                        • Sep 2009
                        • 1002
                        #326
                        Updates: 10th February 2011
                        Bouquet Updates
                        Sky Living (New Frequency)
                        Sky Living Ireland (New Frequency)
                        Sky Living +1 (New Frequency)
                        Sky Livingit (New Frequency)
                        Removed Channels
                        Picons
                        Fixed channels above
                        /usr/share/enigma2
                        /media/hdd
                        /media/cf
                        /media/usb
                        • SGTFlipFlop
                          • Sep 2009
                          • 1002
                          #327
                          Do as markshore said in AV settings choose ac3 default to yes
                          Regards
                          Mark
                          Mine is all mapped to my bouquets, Noticed a few errors on others to why mine doesn't match up on theres. As long as mine works for my bouquets that is all I care about
                          • nobby
                            • 205
                            #328
                            still no living chanels
                            • SGTFlipFlop
                              • Sep 2009
                              • 1002
                              #329
                              Sitting watching them now, They are there
                              • SGTFlipFlop
                                • Sep 2009
                                • 1002
                                #330
                                Too the people who continue to PM me regarding Sky numbering on the bouquets please stop, I will never number the channels to the same as Sky unless images accept the proper way. I hate the way it looks with the empty place holders all over the place.
                                The reason I started making these bouquets was for the neatness, easiness and flow of my set-up and will continue to do so, Dont like the look of them, simple stay away.
                                /Rant over
