SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • nobby
    • 205
    #1366
    its ok now i,ll wait for the main man SGTFlipFLop as he just does the best work
    • D1SHABBA
      • 68
      #1367
      SGTflipflop Jst for advise pick tv is not working....by the way great work.... Really appreciate it and am sure like all others without ppl like u we the armatures will b stuck...***55357;***56835;***55357;***56835;
      • SGTFlipFlop
        • Sep 2009
        • 1002
        #1368
        Yeah doing an update now mate, Should be 20 minutes
        • smirnoff_rules
          • 8603
          #1369
          Originally posted by SGTFlipFlop
          Pick TV & Pick TV +1 was done in last update
          Sky Living +1 still works in current bouquet
          got a feeling it changed again yesterday morning .. might be wrong , found in a scan
          • D1SHABBA
            • 68
            #1370
            That's ok Jst thought I'd let u know....once again thanks to you
            • tipster69
              • 91
              #1371
              Originally posted by seanmckeown
              there is a FTA section in his bouquets
              Thanks for that, I have never spotted that.
              • SGTFlipFlop
                • Sep 2009
                • 1002
                #1372
                Here is the latest update
                DreamboxEdit 5.0.1.0 Used (Recommended) Guide Here
                Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
                Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
                Updates: 7th March 2012
                Bouquet Updates
                Filth Renamed To Reality Hub
                Luxury Life
                Pick TV +1 Renamed Sky2
                Sky Arts 2 (New Frequency)
                Sky Living +1 Ireland (New Channel)
                Sky1 Ireland (New Channel)
                Super 6's (New Frequency)
                Removed Channels
                Community Channel
                LivexxxBabes
                Pick TV
                Sky Arts 2
                Sky1 Ireland
                Sky2
                Super 6's
                Picons
                Updated newest channels
                These bouquets are positioned identical to the Sky Box, All that is different is the numbering which I find to be very messy when done so I leave it how it is. Enjoy a neat up to date bouquet.
                I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
                ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
                Also added Picons for Sky UK,
                All correctly mapped and a few obscure ones missing only
                Use any FTP client, DCC for example, to transfer the picon directory to
                one of the following paths on Flash, HDD, CF or USB respectively:
                /usr/share/enigma2
                NOT recommended, because of limited capacity of the flash memory
                /media/hdd
                HDD will keep running indefinitely and may affect image performance
                /media/cf
                Recommended if CF available and successfully mounted (8000/800)
                /media/usb
                Recommended if USB available and successfully mounted (8000/800)
                Picon will display immediately on zapping, no further setup required!
                Always remove old picons from Dreambox before uploading new ones,
                Sometimes they don't overwrite correctly
                Please keep this thread clean, Use the Thanks button rather than posting on the thread
                • D1SHABBA
                  • 68
                  #1373
                  Sky 2,sumo tv, sky arts 2, crime & investigation network HD, AAG (international one), these the ones I found not working at mo. thnx
                  • SGTFlipFlop
                    • Sep 2009
                    • 1002
                    #1374
                    AAG, Sky2, Sky Arts & Crime all work
                    Sumo TV no idea about that
                    Edit: Remember Crime doesn't start until 8pm hence why no picture now
                    • pyrophoenix
                      • Jan 2012
                      • 11
                      #1375
                      I thought Sumo TV was over long time ago.
                      By the way Sky added up Sky Sports F1
                      • SGTFlipFlop
                        • Sep 2009
                        • 1002
                        #1376
                        Added a few updates ago mate
                        • smirnoff_rules
                          • 8603
                          #1377
                          Pick TV +1 Renamed Sky2 is this showing pick tv with standard decoding ?
                          • Boxfresh
                            • Feb 2012
                            • 16
                            #1378
                            Unfortunately for me since I'm a newbie here, I can't download this bouquet for some reason.
                            • smoggy
                              • Apr 2009
                              • 12774
                              #1379
                              Hi Boxfresh
                              you have to wait until the server updates (15-20 mins)
                              whilst your waiting try here Introduce Yourself
                              say hello and join the community
                              • Akin12
                                • Feb 2012
                                #1380
                                For one reason or another, i can't find Sly sports F1 HD in the sport section of the bouquet? HELPPPP
