its ok now i,ll wait for the main man SGTFlipFLop as he just does the best work
SGTFlipFlop SKYUK Bouquets - Updated Regularly
Last edited by smirnoff_rules; 7 March, 2012, 17:42.any information provided is for educational/experimental purposes only.Comment
Here is the latest update
DreamboxEdit 5.0.1.0 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
Updates: 7th March 2012
Bouquet Updates
Filth Renamed To Reality Hub
Luxury Life
Pick TV +1 Renamed Sky2
Sky Arts 2 (New Frequency)
Sky Living +1 Ireland (New Channel)
Sky1 Ireland (New Channel)
Super 6's (New Frequency)
Removed Channels
Community Channel
LivexxxBabes
Pick TV
Sky Arts 2
Sky1 Ireland
Sky2
Super 6's
Picons
Updated newest channels
These bouquets are positioned identical to the Sky Box, All that is different is the numbering which I find to be very messy when done so I leave it how it is. Enjoy a neat up to date bouquet.
I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Please keep this thread clean, Use the Thanks button rather than posting on the threadCode:Also added Picons for Sky UK, All correctly mapped and a few obscure ones missing only Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
Attached FilesLast edited by SGTFlipFlop; 7 March, 2012, 22:03.
AAG, Sky2, Sky Arts & Crime all work
Sumo TV no idea about that
Edit: Remember Crime doesn't start until 8pm hence why no picture nowLast edited by SGTFlipFlop; 7 March, 2012, 18:25.
Pick TV +1 Renamed Sky2 is this showing pick tv with standard decoding ?any information provided is for educational/experimental purposes only.Comment
Hi Boxfresh
you have to wait until the server updates (15-20 mins)
whilst your waiting try here Introduce Yourself
say hello and join the communityComment
