SKY UK BOUQUETS
This topic is closed.
  • d00k69
    • 26
    #151
    SGT FLIP FLOP.
    o h41 !!!
    • SGTFlipFlop
      • Sep 2009
      • 1002
      #152
      Updates: 7th August 2010
      DM800 Bouquet
      B4U Movies (New Frequency)
      B4U Music (New Frequency)
      Islam Channel (New Frequency)
      Sab TV (New Frequency)
      ATN Bangula UK (New Frequency)
      Channel 'S' (New Frequency)
      Peace TV (New Frequency)
      Peace TV Urdu (New Frequency)
      Blue Kiss TV (New Frequency)
      IQRA TV (New Frequency)
      Removed Channels
      Real Madrid TV
      DM500 Bouquet
      Same as above except HD content
      Hope you find them useful, Please say Thanks
      Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find)
      DreamboxEdit :- Download DreamboxEdit from SourceForge.net
      Also added Picons for Sky UK (Base set from Picon4U) and the rest   updated by myself
      Use any FTP client, DCC for example, to transfer the picon directory
      to one of the following paths on Flash, HDD, CF or USB respectively:
      /usr/share/enigma2
      NOT recommended, because of limited capacity of the flash memory
      /media/hdd
      HDD will keep running indefinitely and may affect image performance
      /media/cf
      Recommended if CF available and successfully mounted (8000/800)
      /media/usb
      Recommended if USB available and successfully mounted (8000/800)
      Picon will display immediately on zapping, no further setup required!
      • lombard
        • Aug 2008
        • 793
        #153
        thanks the SkyUK Picon Pack been updated for new channels ?
        • SGTFlipFlop
          • Sep 2009
          • 1002
          #154
          Always gets updated for new channels, I've went through a lot of channels and added Picons to channels that didn't have any.
          If you know any more that are missing list them here and I'll check them out
          • lombard
            • Aug 2008
            • 793
            #155
            HI, Five HD, ESPN America HD, Sky Arts 1 , picons not showing on these
            • SGTFlipFlop
              • Sep 2009
              • 1002
              #156
              They are, Been showing since I added them to Bouquet, Deffo working just checked
              • SGTFlipFlop
                • Sep 2009
                • 1002
                #157
                New channels often replace old channels with same ID number, Make sure you overwrite the files when uploading to the box
                • mistadizzy
                  • 5
                  #158
                  Thanks for the bouquets
                  • TheUser
                    • Aug 2010
                    Thanks for these.
                    However, some of the channel's picons are not showing and the strange thing is that it is all the HD channels.
                    Any idea why this could be?
                    • bstar111
                      • Jul 2010
                      • 17
                      #160
                      Thank
                      Seems a good list willl give it a go
                      once again for putting efforts
                      • burgemaster
                        • Jul 2010
                        • 33
                        #161
                        Does the channel FIVE HD actually work for you guys?
                        I get TUNE Failed ?
                        • billy2
                          • 1381
                          #162
                          working for me m8
                          please press the little red THANKS tab
                          if I helped if not press the green tab to tell me to f**Koff
                          • fungusfeet
                            • Apr 2010
                            • 6
                            #163
                            I'm trying to watch Football First on the Sky Active Channels right now but they are blank, SA 5 gives me the screen where you would press a number to choose which match but that's it.
                            • SGTFlipFlop
                              • Sep 2009
                              • 1002
                              #164
                              I ain't looked at those channels in a while, I'll need to check into this
                              • fungusfeet
                                • Apr 2010
                                • 6
                                #165
                                While you're at it, you could change Five to the 4th channel in the list 7702/2037, that one is the free to air one.
                                Your bouquets saved me a lot of time, thanks.
