SKY UK BOUQUETS
This topic is closed.
The ones labelled multi are for motorised systems, so has multiple satellites (39 E to 0.8 W) in the bouquet lists.
The other files are Sky UK bouquet lists, so only covers channels on 28.2/28.5 ELast edited by dave-h; 27 August, 2010, 19:15.Comment
Updates: 28th August 2010
DreamboxEdit 3.0.1.7 Used (Recommended)
DM800 Bouquet
Faith Channel (New Frequency)
Good Food HD (New Channel)
National Geographic HD (New Frequency)
oMusic TV (New Frequency)
Showcase +1 (New Frequency)
Sky3 +1 (New Channel)
Removed Channels
DM500 Bouquet
Same as above except HD content
** Reworked the Picons, Please Delete all from box and re-upload **
** Fixed the Radio bouquet matches official box now **
Right here we go, Decided to set myself up a multisat bouquet, As I only watch Sport on these Satellites that's all I have set-up, But a full scan has been done and access to the rest of a Satellites channels will be available via All Channels (DM500) or Services (DM800).
This is still very raw to me as I've just set-up a Motorised dish, So no doubt in the coming weeks I'll make changes, I don't have many Satellites open to see if they all work, So I need updates from you guys, Please leave feedback on these new Bouquets for good or bad I need to know if they work or don't.
On these bouquets Sly UK will always be the main Satellite listed and the rest as feeders.
Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find)
Code:Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required!
Attached FilesLast edited by SGTFlipFlop; 28 August, 2010, 15:43.
Anybody downloaded SGTFlipFlop E? DM500 28.08.2010, Please redownload it, Found an error, Thanks
anyone got an upto date dm600 all sat BOUQUETS pleaseany information provided is for educational/experimental purposes only.Comment
Downloaded to test and Entertainment is there, Thats why I had to fix the Dm500 non Multi one as The Documentaries folder was missing.
I wonder if this new DreamBoxEdit I downloaded last night isnt up to scratch.
Anyone else having hassles?
l have made one now m8 thanx ,., its here if anyone wants itAttached FilesLast edited by smirnoff_rules; 28 August, 2010, 16:46.any information provided is for educational/experimental purposes only.Comment
