DREAMBOX dm500s problem flash
  • jay5880
    replied
    while where on the subject of flashing can someone tell me which is the best image for a 500s im using pli jade at the moment witch im told is the safest thanks
    Leave a comment:
  • ifodon
    replied
    Originally posted by bubbles69
    This patched version of dreamup witch has fix for dm500 lock bits error, and dm800 no ca...
    DON'T FORGET THE THANKS BUTTON
    try many version, will try this also, will come back to tell results
    thank s inf advance
    Leave a comment:
  • allykz
    replied
    I got the same problem and also my other box light stays red and just steady. plaese help
    Leave a comment:
    replied
    Originally posted by meharich
    hi friend i like help i was flashing my dreambox and electricity go off help
    Welcome to dk m8
    have a read of this http://www.digital-kaos.co.uk/forums...dreamup-42950/
    Leave a comment:
  • meharich
    replied
    Leave a comment:
  • eurosatwiz
    replied
    i had similar problem with gen box
    i connected box to network switched off
    connected usb to pc and installed drivers
    installed dream up
    com4 on my system
    started dream up powered dreambox on
    dream up connected to dreambox
    check dhpc server for dhcp address of dream box
    logged in via web interface and uploaded new image
    worked 1st time after many failed attempts using just dreamup
    Leave a comment:
  • anouaros
    replied
    i have the same problem
    error resetting lockbits
    any help please
    Leave a comment:
  • heatonbk
    replied
    Originally posted by Curious123
    People who have used the null modem cables with an USB connector at one end have had issues with the drivers. I would definitely use one without a USB connector. The latest Open Pli images do not work on clones so best to stick with Pli Jade 3 image if you have a clone.
    Curious123, i have the same problem (as below) repeatedly,.. do you have the OLD "Pli Jade 3 image" for Singapore, i am on clone box DM500C from China Anandasy,... please help, thanks
    12:47:58 PM Found no valid jffs2 in image, flash-erase not supported
    Leave a comment:
    replied
    Originally posted by clarkyj
    Same problem here not connecting at all via dreamup v 3.1.3
    Try a different version
    Leave a comment:
  • clarkyj
    replied
    Leave a comment:
  • frabato
    replied
    same problem, i used darkness 2 flash then got same message error
    Leave a comment:
  • andy91
    replied
    If you all started your own threads instead of asking different questions in this one you might have more luck.
    Also introducing yourself in the relevant section might help and having a read of the rules.
    Forum Rules
    Introduce Yourself
    Welcome to the forum
    Andy
    Leave a comment:
  • biomecanoid
    replied
    My dreambox hangs on boot will the erase.img help ?
    Leave a comment:
  • csabitus
    replied
    Dm 500
    hi
    I can't make a flash update it wont leave acknowledgement
    Pls help
    Leave a comment:
  • nar_di
    replied
    my dm500 can't boot
    Leave a comment:
