so tell me what happens,
you push connect in dreamup up.
power box
do you get acknowledgement from box dm500?
do you get as far as flash erase ?
do you the flash full image 7.936mb?
DREAMBOX dm500s problem flash
This patched version of dreamup witch has fix for dm500 lock bits error, and dm800 no ca...
DON'T FORGET THE THANKS BUTTONLeave a comment:
Try the oldest version of Dreamup you can find and flash this to your box. After flashing the erase image you then need to flash your image of choice.Attached FilesLast edited by Curious123; 23 April, 2010, 11:02.Leave a comment:
same here Im still waiting someone who can help us out...
tried evrything nothing FAIL FAIL FAIL
Leave a comment:
I'm having similar problems as vasilism13.
tried erase.img and it gives me same message:
No valid jffs2, Flash-erase not supported.
Tried erase with DreamUp, but get lock-bit error.
Upload img without erase gives upload error.
All very frustrating. Have tried 3 versions of DreamUp and even tried a version of DreamUp for Linux.
All similar results. Anyone run into a problem like this?
TIA for any helpLeave a comment:
hello my friends i had a dm500s with pli.
the box stopeed boot and i tried to flash it with null cable and dream up.THe problem is that when i upload an image (yes i tried the official) dream up has the opinion to select an erase flash or not.
if i press yes dream up gives me this :
ERROR, flash-erase failed, box will be unusable now!!
if i press no upload and flashing is ok but box cant boot,
stacks when i select the time, and makes a reboot.
i have watched-but cant see because it appears for a very litle time-an error message to my screen with a X symbol when tries to boot after time selection.
i have tried a diferent machine, a different ccable and the images: rl (oficial) , gemini , pli , nemesis.
erase.img gaves me this :Found no valid jffs2 in image, flash-erase not supported
any suggestion plz?
edit- sorry for my english!
Leave a comment:
