DREAMBOX dm500s problem flash
What type of null modem cable are you using i.e does it have a USB connector? Try d/l and installing the original from DMM and then your preferred image.
Downloads | dream-multimedia-tv.de
I have the same problemLeave a comment:
i have an origianl box.People who have used the null modem cables with an USB connector at one end have had issues with the drivers. I would definitely use one without a USB connector. The latest Open Pli images do not work on clones so best to stick with Pli Jade 3 image if you have a clone.
you think is damaged?Leave a comment:
People who have used the null modem cables with an USB connector at one end have had issues with the drivers. I would definitely use one without a USB connector. The latest Open Pli images do not work on clones so best to stick with Pli Jade 3 image if you have a clone.Leave a comment:
every image worked but stucks to language selection.Has there been an image that has worked on the box and if so which was that? What was the last image you flashed on the box? Are you using a null modem cable with an USb connector at one end? What version of Windows are you using and is your firewall tured off? Have you tried the latest DreamUP and the oldest DreamUP?
i have tried to windows xp,7 with usb adapter and without.
last image worked correctly was pli.Leave a comment:
Has there been an image that has worked on the box and if so which was that? What was the last image you flashed on the box? Are you using a null modem cable with an USb connector at one end? What version of Windows are you using and is your firewall tured off? Have you tried the latest DreamUP and the oldest DreamUP?Leave a comment:
i have null cable modem of course.
if i dont flashing first when i upload an image dream up aske me if i want to perfome a flash erase or not.
if yes i got the problem flash erase failed.
if no flashed ok but box cant boot.
staucks to the language selection.
the dreambox is not a clone!
i have just watched the led became red when perfoming the flash erase.
and auto swiched on-ofLast edited by vasilism13; 27 April, 2010, 13:42.Leave a comment:
i have tryed it!But i have the following problemWhat type of null modem cable are you using i.e does it have a USB connector? Try d/l and installing the original from DMM and then your preferred image.
(see my next post)Leave a comment:
This normally happens if you don't manually flash erase before flash?
Are you flash erasing first?Leave a comment:
Leave a comment:
yes i am trying full image.
the box stucks every time near the end of the flash erasing status bar giving me the following error:ERROR, flash-erase failed, box will be unusable now!!Leave a comment:
Leave a comment:
