Oscam + CCcam 2.1.3
  • kopkidda
    • 122
    #181
    Thanks, does your server config block emms?
    • Rodbouy
      • Jul 2010
      • 1320
      #182
      blocks unknown and global
      • kopkidda
        • 122
        #183
        Thats the job good man, so If I enter all details that I need to and put card into box channels should clear?
        What sort of line do I put into receiving box then?
        • Rodbouy
          • Jul 2010
          • 1320
          #184
          If you have all the correct files in the correct places then yes.
          Depends on how you setup your local.
          Some using OScam with CCcam to help control it.
          I use OScam with anticacs enabled and dvbapi enabled to help control and AU the card.
          But by adding the user pass to oscam.users and in your say bedroom box add the cline as you normally would.
          Just remember to enable the CCcam protocol to oscam.conf
          • kopkidda
            • 122
            #185
            Thanks you have a PM
            • pem1
              • 7
              #186
              hi all could you please post the install file to manually install oscam&cccam on black hole image cheers m8
              • Rodbouy
                • Jul 2010
                • 1320
                #187
                if you read through this mate you will see a few configs then just google the oscam emu and you will get there.
                • davvo
                  • Apr 2009
                  • 666
                  #188
                  you will find
                  oscam/cccam for blackhole image
                  post 98 below
                  post 29 below for the config files
                  • kennyboy
                    • 13
                    #189
                    Originally posted by smirnoff_rules
                    can someone pm this file or the file l would need for a dm500 pli img this isnt working now cheers
                    can this image be put on db 500s hd at the moment im useing nemisis but e2 svn 83 i have been playing with oscam but having some problems i will post my config in abit im trying to find a image that as them built in i like nemisis but i dont mind changeing images thanks
                    • kennyboy
                      • 13
                      #190
                      well ive been trying alday with different configs of ere this is what ive done but it still dont work
                      oscam config
                      [global]
                      Nice = -10
                      WaitForCards = 1
                      PreferLocalCards = 1
                      saveinithistory = 1
                      [monitor]
                      port = 988
                      monlevel = 4
                      nocrypt = 127.0.0.1
                      [webif]
                      httpport = 10001
                      httprefresh = 5
                      httpallowed = 127.0.0.1,192.168.x.xxx- (should this be db ip addy ) 192.168.255.255
                      [dvbapi]
                      enabled = 1
                      boxtype = dreambox
                      user = xxxx xxxxx
                      au = 1
                      oscam server
                      [reader]
                      label = slot1
                      enable = 1
                      protocol = internal
                      device = /dev/sci0
                      detect = cd
                      caid = 0963
                      ident = 12000@0963:000000;12001@0963:000000
                      group = 1
                      emmcache = 1,3,2
                      oscam user
                      [account]
                      user = dreambox
                      pwd = xxxx xxxxx
                      monlevel = 0
                      uniq = 0
                      group = 1,2
                      au = 1
                      caid = 0963
                      any help please i want to keep cccam thanks
                      • kennyboy
                        • 13
                        #191
                        well every1 seems to be sleeping downloaded files from ere trying to use oscam but it seems to me know 1knows my answaers thanks
                        • davvo
                          • Apr 2009
                          • 666
                          #192
                          you dont NEED to muck about with different configs
                          the only configs you need to get oscam working with cccam
                          with your sly card are on page 2 of this thread
                          they are ready to go no need to edit
                          install oscam/cccam as 1 package on your box
                          download the configs put in them in var/tuxbox/config
                          put N-line in cccam cfg
                          restart oscam/cccam
                          thats it
                          the configs you posted 2 post up are wrong and will not work
                          you have the ident as the newcamd port and caid ???
                          you have dvbapi enabled and set up wrong
                          your not using dvbapi ?????
                          download the files on page 2
                          • kennyboy
                            • 13
                            #193
                            restart oscam/cccam
                            thats it
                            thanks for your reply im going to use them now i am useing nemisis 2.2 svn 84 i cannot find oscam/cccam on there downloads what i have downloaded is cardserver oscam_r4396 and useing cccam 213 i think ill google it cannot find it anywhere unless you can point me to it thanks
                            • tjay78
                              • Apr 2009
                              #194
                              Super now my also work...
                              Thanks...
                              • bugaloo41
                                • 1598
                                #195
                                Wonder if anyone can clarify please.
                                Looking to block any possibility of updating entitlements to sly card
                                Am I right in thinking that adding this to your server config should do the trick:-
                                audisabled = 1
                                My set up is oscam and using dvbapi.
                                Conflicting reports some indicate that no need to block as it wont update - just wondering if anyone using similar set up can confirm.
