Oscam + CCcam 2.1.3
  • Rodbouy
    • Jul 2010
    • 1320
    #316
    Can you still not get in to the webif?
    How are you installing OScam?
    State steps your doing to give us a better understanding?
    Try switching to PLi Jade and manually adding OScam?
    • faridbou
      • Nov 2011
      • 24
      #317
      Hej Roudbouy:
      Iam using gemini E1 now i have give up wil use pli image and I wil let you now juste give me 15minute thaksn
      • davvo
        • Apr 2009
        • 666
        #318
        try with all 3 aeskeys
        • faridbou
          • Nov 2011
          • 24
          #319
          Davvo
          Nothing stil not working even i am juste using oscam1.00 it should be easy to work with tnt card
          best regard
          • garry1312
            • Oct 2010
            • 2178
            #320
            Update for use on my side guys.
            within my router there is settings for Dynamic Dyns so I put all my details in there username password, address and since then I have had no cut offs and running very well.
            So dont know if for some reason it was not always connecting to dyndns and if this has resolved that issue.
            Dont want to get my hopes up just yet but looking good the now.
            Satsmo did you see my other reply to you regarding the files? As the script would still be of interest to me.
            Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
            • davvo
              • Apr 2009
              • 666
              #321
              gary try this
              next time it happens
              google whats my ip (note the ip)
              then log into your dyndns account at dyndns dot com
              go to my host and check the ip they should both match
              • garry1312
                • Oct 2010
                • 2178
                #322
                Thanks Davvo will give that a try if it occurs again.
                Fingers crossed it doesnt
                • Rodbouy
                  • Jul 2010
                  • 1320
                  #323
                  Originally posted by faridbou
                  Davvo
                  best regard
                  Is the WebIF opening up?
                  So we know if OScam is working or its just the configs?
                  • satsmo
                    • 6397
                    #324
                    I did just now Garry. I would leave the script for now as it looks like a straight forward IP routing issue, to which you may have resolved now.
                    I compiled Oscam to my specific set up and it is on a standalone server and an external reader, so will not be exactly the same as your set up or Oscam binary. But you could easily configure it to match with a few edited commands.
                    • faridbou
                      • Nov 2011
                      • 24
                      #325
                      Davvo:
                      No it thas not open webinf oscam .
                      but with cccam2.21 using peter pan it open with ip 10.0.0.*:16001does open
                      • garry1312
                        • Oct 2010
                        • 2178
                        #326
                        Thanks sats much appreciated will see how it goes as all is looking well at the moment but still early days but it has been on longer this time without any issues than it has before
                        • faridbou
                          • Nov 2011
                          • 24
                          #327
                          Cccam2.1.3/Oscam1.00 or oscam1.00/Cccam2.1.3 is it to same? in dm
                          2: image pli dm7000 is it to same procedure as gemini var/bin/tuxbox ?
                          thaks
                          • faridbou
                            • Nov 2011
                            • 24
                            #328
                            Hej this is all what i did :
                            downl Cccam2.1.3/Oscam 1.00 and i have put it in:
                            var/tixbox/conf
                            oscam conf:
                            [global]
                            nice = -1
                            WaitForCards = 1
                            ClientTimeout = 5
                            CacheDelay = 120
                            saveinithistory = 1
                            PreferLocalCards = 1
                            [newcamd]
                            Key = 0102030405060708091011121314
                            Port = 34001@0500@030B00
                            [webif]
                            httpport = 16002
                            httpuser =
                            httppwd =
                            httprefresh = 10
                            httpallowed = 127.0.0.1,192.168.0.100-192.168.0.200 her I realy don?t now where to put my dm ip 10.0.0.2
                            Cccam conf;
                            N: 127.0.0.1 34001 test1 test2 01 02 03 04 05 06 07 08 09 10 11 12 13 14
                            oscam server;
                            [reader]
                            Label = tntsat
                            Protocol = internal
                            Device = /dev/sci0
                            detect = CD
                            Group = 1
                            caid = 0500
                            AESKeys = [EMAIL=*****************************/EMAIL]
                            oscam user
                            [account]
                            user = test1
                            pwd = test2
                            group = 1
                            au = tntsat
                            guys your are my last hope to get TNT carde working
                            • Rodbouy
                              • Jul 2010
                              • 1320
                              #329
                              Mate start from scratch.
                              Load Pli jade 3
                              then MANUALLY install OScam. Get the latest stable build from their site
                              oscam-stable-1.10-powerpc-tuxbox-old-webif-Distribution.tar.gz
                              Thats the file you want. Google the oscam forum
                              Then follow my steps a few post back.
                              • satsmo
                                • 6397
                                #330
                                Use Oscam and dvapi do not use CCcam for TNTsat.
                                We can do Oscam here Rod
