Oscam + CCcam 2.1.3
  • faridbou
    • Nov 2011
    • 24
    #331
    thanks guys i hav downl pli image and i am going to do that
    • satsmo
      • 6397
      #332
      Just remember to stay away from CCcam as the non standard ecm lengths for TNT stop it from working. So use Oscam and dvbapi as said with the three AES keys. (Please do not post the keys on the forum).
      Hypercam 2.15 will also work with your card. Have you got an old Via 3.0 version or later version?
      • faridbou
        • Nov 2011
        • 24
        #333
        hej yes satsmos I hav got a viaccess 3.0 version TNT FRENCE yes i would like to tray with hypercam but i don?t thing they made hyper1.15for dm 7000
        • davvo
          • Apr 2009
          • 666
          #334
          oscam with dvbapi
          for TNTsat
          just put the AESKeys in oscam server
          oscam conf
          [global]
          nice = -1
          WaitForCards = 1
          ClientTimeout = 5
          CacheDelay = 120
          saveinithistory = 1
          PreferLocalCards = 1
          [webif]
          httpport = 16002
          httpuser = faridbou
          httppwd = faridbou
          httprefresh = 10
          httpallowed = 127.0.0.1,10.0.0.2-10.0.0.99,192.168.0.2-192.168.0.100,192.168.1.2-192.168.1.100,192.168.2.2-192.168.2.100
          [dvbapi]
          enabled = 1
          au = 1
          boxtype = dreambox
          user = user1
          oscam server
          [reader]
          Label = tntsat
          Protocol = internal
          Device = /dev/sci0
          detect = CD
          emmcache = 1,3,2
          Group = 1
          caid = 0500
          AESKeys = 0500@030B00:[COLOR=Yellow]PUT-THE-AESKeys-HERE[/COLOR]
          oscam user
          [account]
          user = user1
          pwd = anypass
          group = 1
          caid = 0500
          au = tntsat
          • Rodbouy
            • Jul 2010
            • 1320
            #335
            Originally posted by satsmo
            Use Oscam and dvapi do not use CCcam for TNTsat.
            We can do Oscam here Rod
            Of course we can
            Just showing him the daily builds so he doesn't get too lost.
            • faridbou
              • Nov 2011
              • 24
              #336
              hej Davvo :
              is it because Iam using Cccam2.1.3/Oscam1.00 are making problem for me ? or I am the only one not getting thinks here not right.
              I will keep trayin in tll it work .
              I trayit pli image it is litle bit complex for me right now
              Ihave put the aes key in the right place ,
              thanks guys for giving me a hope but stil nor working ad the TNT card expired in dec2012
              • Rodbouy
                • Jul 2010
                • 1320
                #337
                Mate, The CCcam side of it is for sharing. As of right now thats not your problem.
                You need to focus on reading the card.
                Did you install PLi Jade 3 ?
                Did you manually install oscam (not from the downloads section with the image?
                • faridbou
                  • Nov 2011
                  • 24
                  #338
                  Yes Rodbouy have donwlaod oscam and put it manualy
                  pli image doest not have oscam ,I had to donwlaod oscam and put it manualy from oscam page
                  thakns
                  • garry1312
                    • Oct 2010
                    • 2178
                    #339
                    Another couple of questions guys.
                    How can I access my Oscam Web interface remoteley for instance when at work or out?
                    Do use know any crond manager plugins that will allow me to restart oscam or receiver every 24 hours?
                    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
                    • Rodbouy
                      • Jul 2010
                      • 1320
                      #340
                      You just set the up range in oscam.conf but I woukd stronlgy advise against it. Also open.port on the router.
                      Don't worry about re starting oscam mate, no need. It will tell you if it needs re started. Just let it run
                      • garry1312
                        • Oct 2010
                        • 2178
                        #341
                        Was this for me and if so whats the up range and what is this for remoteley connecting to server or restarting oscam every 24 hours.
                        • Rodbouy
                          • Jul 2010
                          • 1320
                          #342
                          Both mate.
                          I would stear clear of allowing outside connections to the oscam webif.
                          If anything open up port 80 on your router for your box up and make sure you have the web if of the box password protected then a simple reboot will reset oscam most of the time
                          And no need to restart oscam unless your having problems
                          • davvo
                            • Apr 2009
                            • 666
                            #343
                            @garry
                            this is a post from the oscam forum
                            You need to have a dyndns for the outside machine and one for the oscam machine.The dyndns of the outside machine must be mentioned in the webif section of the oscam config like this:
                            [webif]
                            httpport = 6250
                            httpuser = user
                            httppwd = pass
                            httprefresh = 10
                            httpallowed = 127.0.0.1,192.168.1.1-192.168.1.254
                            httpdyndns = dyndns of outside machine
                            of course on you router you must redirect the port 6250 (the one used in the exemple; it may be changed) to the machine with oscam.
                            • garry1312
                              • Oct 2010
                              • 2178
                              #344
                              No other way around it, what im thinking is what if I am away on holiday and it needs restarted, there would be no way of doing so unless I could access the webif.
                              Woke up this morning Mrs turned on the receiver and oscam was not reading the card so had to restart Oscam.
                              Been told by some that it is best to restart Oscam about every 24 hours to keep it running smoothly. Know I can do this manually but would rather be able to set a time on it.
                              • Rodbouy
                                • Jul 2010
                                • 1320
                                #345
                                every 24hrs is way to much over kill.
                                I have been running OScam for some time now and ONLY ever restart if I have problem.
                                If your having to restart every 24hrs then some is wrong.
                                I would recommend running the card from a 500s too, much more reliable for a single card setup up.
                                You can restart the cardserver from the remote control function of the the box webif.
                                By allowing more outside connections direct to the control of OScam is only opening up more possible pitfalls.
