Page 327 of 462 FirstFirst ... 227277317322323324325326327328329330331332337377427 ... LastLast
Results 4,891 to 4,905 of 6927
  1. #4891
    May 2014
    Please help me
    Need picture volvo s60 soldering point 912gd128 a
    Not 9s12.
    St51 cable
    Good job?
  2. #4892
    DashProg's Avatar
    Jan 2013
    Here
    Quote Originally Posted by evo1974 View Post
    Please help me
    Not 9s12.
    St51 cable
    Good job?
    You'll find what you search here https://mega.nz/#F!A41kFDoC!_PJTqzEogjjDsR1grx4TEA
    Envoy? de mon ASUS_T00J en utilisant Tapatalk
    Everything will be back in order - All my respects to DK's members.
  3. The Following User Says Thank You to DashProg For This Useful Post:
    jomberykaso (8th August, 2016)
  4. #4893
    Dec 2010
    vietnam
    anyone help me confirm SN: FA746016000 up to 4.94
    mainboard is no FT232. I have a new solder, but the computer does not recognize.
    anyone have a solution?
    Thank you very much
    SOLVE! thank.
  5. #4894
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Default 2008 hyundai tucson 2.0 gls dash dump
    tucson 2008 2.0 gls petrol manual.rar
    Quote Originally Posted by olegario View Post
    Tucson c46 via clip OK
    Howzit guys need some help please ... see my dump files ori is 207 073km and mod file is 148 000km
    I read with digiprog 4.94 and tuscon - c46 and seems fine even when I check file with tachosoft and dashboard tool
    When I solder back on cluster it reads 8000km and also the on board computer displaying average consumption - kilometres till emprty etc. is also missing - any advise or something I could be doing wrong - anybody with a working dash dump for this vehicle or that can check my dump if it is fine
    'If I helped, please click Thanks +Reputation.. !'
  6. #4895
    DashProg's Avatar
    Jan 2013
    Here
    Quote Originally Posted by rtbdiagnostic View Post
    I think you must read it as 16bits
  7. #4896
    clusters's Avatar
    Mar 2015
    Canada
    Look a little harder in your dump, seems like you didn't change all places. Tachosoft not always the best.
  8. The Following User Says Thank You to clusters For This Useful Post:
    rtbdiagnostic (27th August, 2015)
  9. #4897
    Moderator
    PremierD's Avatar
    Jun 2009
    "Tachosoft not always the best." ... thats why its known as Tachosh1t mate ..
  10. The Following User Says Thank You to PremierD For This Useful Post:
    DashProg (27th August, 2015)
  11. #4898
    Moderator
    PremierD's Avatar
    Jun 2009
    Your altered dump should read 148,003 mate .. so check elsewhere
  12. The Following User Says Thank You to PremierD For This Useful Post:
  13. #4899
    May 2015
    My Tool Room
    Quote Originally Posted by clusters View Post
    ori207073 to128000km.rar
    Would this algo maybe work I tried the sant? fe 93c46 - 2007 year as algo and the mileage to 128 000km from 207 073km
  14. #4900
    Jul 2009
    Has anyone had any luck with using dijiprog on GMC YUKON or Escalade 2011 or 12 model. I believe these can be done via obd with tools like DSPIII. Anyone had any luck?
  15. #4901
    May 2015
    My Tool Room
    FYI
    I used the algo for santa fe and it worked 100% -
  16. The Following User Says Thank You to rtbdiagnostic For This Useful Post:
    clusters (28th August, 2015)
  17. #4902
    Dec 2010
    vietnam
    FYI
    you need to memorize the denso algo. it is very easy. remember:
    F = 0
    E = 1
    D = 2
    C = 3
    B = 4
    A = 5
    9 = 6
    8 = 7
    7 = 8
    6 = 9
    it as: 12345 = BADCFE
  18. The Following 2 Users Say Thank You to hoangtu For This Useful Post:
    cklair (29th August, 2015), rtbdiagnostic (29th August, 2015)
  19. #4903
    Mar 2013
    Europe
    Digiprog 4.94
    Ford Focus 2011 Keyless GO ---> EEPROM 95320 WORK
  20. The Following 3 Users Say Thank You to bersch8688 For This Useful Post:
    hoangtu (29th August, 2015), rtbdiagnostic (12th October, 2020), thomas2mileage (31st August, 2015)
  21. #4904
    Aug 2015
    Hello, I have a problem with my DigiProg 3. I've bought a Chinese clone and I tried it on a Golf 4. I connect the OBD cable to the car, go to car selection menu, chose the option that's needed in that situation and It shows the old km like this: OLD ? and it prompts me to give it a new value, I enter the new value, and it starts to say try 0, try 1, try 2 etc. and after a while it says NO CONNECTION. I've tried this on 3 different Golf 4 cars, a model from 2003, one from 2004 and one from 2005.
    I've tried it on a Skoda Octavia II from 2005 and on a Audi A6 from 2006 and it worked on both cars.
    Can it be a problem from the adapter, or from the DigiProg 3, or it just doesn't work on Golf 4. I have a friend that knows a guy who works with the same device and can change the km with digiprog on golf 4, but you know how it goes, maybe it isn't true!
    Should I try to put another update on it? It's already 4.94!
    Thank you very much!
  22. #4905
    Dec 2010
    vietnam
    Quote Originally Posted by negatiw View Post
    you are new members on the 4rum and you use red font? Try the search button in This Post and write in Golf 4.
