Page 60 of 78 FirstFirst ... 1050555657585960616263646570 ... LastLast
Results 886 to 900 of 1158
  1. #886
    ray-ray's Avatar
    Nov 2009
    I’ve done a 2017 key the remote section took some time in getting it wright.
  2. #887
    Dec 2017
    Any tips? I'll be using a non-remote head key.
  3. #888
    Jul 2010
    Default 2006 Lexus LS430 Smart key with Twist knob
    Hi, ray-ray
    Do you have any idea how to programming smart key function with this car?
    I programmed immobilizer function with Autopropad .
    but there no smart key or remote function option on Autopropad.
  4. #889
    Jan 2017
    USA ����
    Quote Originally Posted by lock-key View Post
    Hi, ray-ray
    manual on board programming for that part
    its non diagnostic
    Driver's door open, all other doors closed, key removed from ignition
    switch.
    Within 5 seconds:
    Insert and remove the key from the ignition switch twice.
    2. Within 40 seconds:
    Close and open driver's door twice.
    Insert and remove the key from the ignition switch.
    3. Within 40 seconds:
    Insert the key into the ignition switch and close the driver's door.
    4. Switch ignition ON and OFF:
    A. Once to program a key remote transmitter code whilst retaining the
    original codes.
    B. Twice to program a key remote transmitter code whilst erasing the
    original codes.
    C. Three times to check how many key remote transmitters are currently
    registered.
    D. Five times to erase all registered codes.
    5. Remove key from ignition switch. System should now lock and
    unlock vehicle
    once, twice or five times depending which mode has been
    selected. One to four
    times, slowly, to indicate number of key remote transmitters
    registered.
    6. Within 40 seconds:
    Press and hold LOCK and UNLOCK buttons simultaneously for
    1.5 seconds.
    Within 3 seconds: Press any key remote transmitter button.
    System should now lock and unlock vehicle once to confirm
    registration or twice
    to indicate registration has failed.
    7. Within 40 seconds:
    To program additional remotes repeat step 60 now on each
    additional
    remote you want programmed.
    8. To exit programming mode open driver's door or insert key into
    ignition.
    9. Step out of car with remote(s) in hand and test remote(s).
    The thanks button is HERE looks like this --->>> THANKS
  5. The Following 2 Users Say Thank You to sleepyrz For This Useful Post:
    kitten13 (18th December, 2018), VictorVonDoom (13th December, 2018)
  6. #890
    Jul 2010
    On board programming is not working. Because Smart Entry function!
  7. #891
    Jul 2010
    Quote Originally Posted by sleepyrz View Post
    its non diagnostic
    switch.
    Within 5 seconds:
    original codes.
    original codes.
    registered.
    unlock vehicle
    registered.
    1.5 seconds.
    additional
    ignition.
    Is this processor for twist knob with smart key function car ?
    Have you job done with those type vehicle (Twist knob with Smart key)?
  8. #892
    Jan 2017
    USA ����
    its straight from the advanced diagnostics manual
  9. #893
    Jul 2010
    You may be also see "For Smart entry LS430 and other models not listed here" AD Manual
    "Not supported by tool or Tech Support"
  10. #894
    ray-ray's Avatar
    Nov 2009
    So if no support by AD company that been working on immo. For 20yrs. It not going to be a available on any tool. Dealer required one working key to register a second Proxy.
  11. #895
    Jan 2017
    USA ����
    really..........
    you have a smart entry ls430 right?
    they are just saying there is no procedure on the machine that will do it and they dont support it because the machine is not doing it YOU ARE
    IT IS AN ON BOARD PROCEDURE
    look here read what it says
    it says it is provided as a courtesy but it is not supported by tech support since AGAIN their machine does not do anything IT IS YOU DOING IT ON BOARD.
    did you try it ?
    do you even have the right key?
    did you read the car to see if their are any trouble codes?
    cmon man give us some info here
    but this literally says the machine doesnt do it
    do it yourself by OBP
    so wheres the problem here?
  12. #896
    Jan 2017
    USA ����
    read this part too if it helps
    Attachment 576032
    Note: Only the immobilizer can be programmed with the PRO. Use on board programming to program the PROX!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
    so again what part of this is escaping your grasp?
    if you tried and it didnt work
    you probably didnt do it right?????
  13. #897
    Jan 2017
    USA ����
    Quote Originally Posted by ray-ray View Post
    he has one working key that starts the car........
    look below
    Hi, ray-ray
    so dont see why this wouldnt work.....
    maybe im missing something here?
  14. #898
    Jul 2010
    really..........
    did you try it ?
    I done by OBP. I'm stock at #6 this part (twice to indicate registration has failed)
    I purchased new twist smart entry key from Lexus dealer by the VIN.
    I scanned with AVDI to pull up DTC. Save and cleared DTC, before program processor begin.
    There is nothing special DTC with immo and smart enrty system (A/C, Suspension...)
    Reason for I ask ray-ray, He has same post I have questions.
    Refer: http://www.digital-kaos.co.uk/forums...ht=ls430+twist
    If OBP only the correct procedure for those year car then I assume this car has problem.
    Anyway thanks for your help sleepyrz !
  15. #899
    Jul 2010
    look below
    All key lost situation.
    I have programmed key only insert ignition slut to start.
    This car has two function.
    One function is insert key ignition slut to start the car, when smart key button battery died.
    Second is without pull out smart key just press door handle button to open door and twist knob to start the car.
    Just like newest Lexus smart key functions, only difference is twist knob and push start button.
  16. #900
    Jul 2010
    Dear ray-ray,
    Do you solve the problem previous job ?
    Please refer your past post:
    Let me know...
    Thank you
