i did read 93c46 or 93c56 (i dont remember) from renault immobox via socket
Hi . I have read clusters eeprom and clear first two lines.. but how can i know on which position should i write the new milage? I mean shall I type the new milage on the beginning of the first row, or to the end of the 2nd row?
can somebody modify the bin file to set milage to 91 000km? - i have masked the vin. thanks
SRS DUSTER 2017
alclot (13th May, 2019), amaflo (24th April, 2019), barho67 (22nd April, 2019), danielif (23rd April, 2019), galaxy0634 (22nd April, 2019), habbyb (22nd April, 2019), harciogu (24th April, 2019), hohoeho321 (1st January, 2024), laki23 (23rd April, 2019), nstnkt (29th September, 2021), Perryking (23rd April, 2019), PocketHero (22nd April, 2019), racin-snake (10th May, 2019), SALAS (27th July, 2019), ThiagoArgentino (24th April, 2019)
camouflaged (22nd April, 2019), mickye_dj (22nd April, 2019)
hi. thank you again. ok. i will. how did you calculate the new milage? thanks. In conversion 91000 dec > hex is 16378, why is it only in yours 16 37?
1637 > dec * 16 is the algo mate![]()
camouflaged (23rd April, 2019), danielif (23rd April, 2019), daxxer (23rd April, 2019), PocketHero (23rd April, 2019)
thats what i needed to know ! thank you so much !
Samic how can i update my vvdi prog if dont connect to your server !!!
only 4.8.1 but every time i open soft cames the messenger to update to 4.8.3 but when i try dont conect to server...
One for all and all for one!!!
gtcricardo (24th April, 2019)
Can you please share 4.8.3 software link?
Today i had to reset mileage and change VIN on F30 cluster. Inside it had 35160WT chip and i don't have vvdi prog adapter for it so simply did read it as D160 and i also had broken cluster with D160 chip so i wrote all memory from 35160 to D160, reset mileage and changed VIN and cluster works perfectly!![]()
Red dot in these dashes is due to vin and id...if vin is ok fem or dash gets the highest value...
Professional BMW immo solutions
Macedonia is one and GREEK!!!
