Page 828 of 854 FirstFirst ... 328728778818823824825826827828829830831832833838 ... LastLast
Results 12,406 to 12,420 of 12803
  1. #12406
    Top Poster MrDerv's Avatar
    Mar 2023
    UK
    Quote Originally Posted by a1pp4 View Post
    Here is some pictures from that item,
    Does anyone know what component U6 is? It has no writing...
    Seems this is same what aliexpress etc sells? Can anyone say is there something false? Its pretty laggy on k-line audi, atmega works alot better and faster
    That will definitely need the loader then if you are going to do anything that requires coding/security access
  2. #12407
    Aug 2020
    Quote Originally Posted by Billyym View Post
    Attachment 995257
    Attachment 995258
    Anyone seen this error and how to resolve. Have tried vcds 22.10, 23.3 and 23.3.1 and still no luck .
    YES MAN!
    1st step: you must have already installed the VIIPlus Loader(compatible with vcds software) and the vcds software. The icons must be on desktop.
    2nd step: with your vcds cable connected only open VIIPLus Loader (dont press start vcds or more info...) and on this VIIPLus Loader opened DRAG the icon vcds.exe from desktop to VIIPlus Loader and automatically will run and start that software.
    The reason of your error it is that the VIIPlus Loader only run and start the latest vcds software opened before. And an old software it is now it his memory...
    Dont forget to THANKS me!
  3. The Following 3 Users Say Thank You to Pater Fortunato For This Useful Post:
    amstel7 (10th November, 2023), Col19 (29th April, 2024), Rakija (30th November, 2023)
  4. #12408
    Jun 2020
    Hi, maybe you have the firmware for this cable?
    The cable does not work.
    STM32F405...
    B03-ST v23.3
  5. #12409
    Jun 2020
    Hi, please download link this soft. Thanks
    Quote Originally Posted by Screpicoco View Post
    Hello. why doesn't it detect my stm 405 cabl
    e Attachment 994376
  6. #12410
    Jun 2020
    Hi, did it work? Please link.
  7. #12411
    Jun 2020
    Quote Originally Posted by maniak321 View Post
    Hello Badrax, can u help me back to life my cable STM32F405?? How i can reflash this cable?? Via uart STLink? PLS send to me
  8. #12412
    Dec 2020
    Quote Originally Posted by Tomas003 View Post
    STM32F405...
    B03-ST v23.3
    If you are lucky then you can flash this with the FLY firmware I released some time a go using a STM debugger. I think this type of cable might be preset to RDP1.
    But if this cable was bought to use with any newer version of VCDS then 20.4.1 it is probably already flashed with this FLY firmware and you tried to upgrade it using VIIPlus loader? If this is the case then you are out of luck and cable is bricked.
  9. The Following User Says Thank You to badrax For This Useful Post:
    Tomas003 (11th November, 2023)
  10. #12413
    Jun 2020
    Yes, software 23.3. VIIPlusLoader update required:
    Stuck during update.
    Can it be fixed?
    Quote Originally Posted by badrax View Post
  11. #12414
    Nov 2009
    Usa
    HI
    I need help with VIIPlusLoader 08.023.07 for VCDS 23.3.1
    device not found
    I don't know if the problem is from the loader or from the cable
    I have this cable
    thx
  12. #12415
    Newbie Pfennig's Avatar
    Sep 2023
    by the look this is not a stm32-chip... the VIIPlusLoader will not work with this version of the device.
  13. #12416
    Sep 2023
    badrax,
    where can I download your loader? I want to try to flash my dead cable... thx in advance.
  14. #12417
    Mar 2023
    UK
    Quote Originally Posted by quikcar View Post
    HI
    device not found
    I have this cable
    thx
    ViiPlusLoader will not work with that device. Its not STM32 based
  15. #12418
    Dec 2019
    Romania
    Do you guys know if there is a new loader for 23.11 or it works with the old loader that we used for 23.3 ?
  16. #12419
    Nov 2023
    Hello guys
    I have problem with long coding.
    I can do auto scan but when i try long coding and input security access key i get: Controller refused the key!
    Error 00: Unknown (0x00)
    What can i do?
    My car is seat ibiza 2017
  17. #12420
    Nov 2023
    Badrax, is it your cable?
