All discussion on SGSH Bouquet only applicable to
Dream Multimedia (DM) 500C/800C HD/800C SE only.
Do not use this method if box is not Dream Multimedia model.
Edited & updated of SGSH channel list as of 29072013,
added new channel
For E2 Box only
463 Crime & Investigation Network HD
464 The Biography Channel HD
562 WarnerTV HD
755 BBC World News HD
760 CNN HD
Added new freq 157 Symbolrate 6090 in cable XML useful for E1 user
Box must connect to router
In XML format for reference as of 29072013
29072013 SGSH Channel List In XML format - Downloads - Digital Kaos
For E1 DM500C as of 06062013
SGSH Bouquet 06062013 E1 500C - Downloads - Digital Kaos
For E2 DM800/800SE as of 29072013
SGSH Bouquet 29072013 E2 800 & 800SE - Downloads - Digital Kaos
Complete Tools/Program for Dreambox
Open PD DreamboxToolbox v.9.0
Open DB edit
PROFILES:
option/profiles/new profile/set your box model & ip address/the rest just leave as default/test ip connection/after successful select enigma 2 setting for 800 series/cable receiver for 500 series enigma 1/save profile/save.
GENERAL:
Tick box 1/3/4/enable zap function/save.
Tick all box
FTP:
Tick enable quick ftp send/issue reload command.
COLOR SCHEME:
Select whatever color u like
ADVANCED:
Tick Allow duplicate entries / display reboot
PICON:
Tick show picon for service/40X30 picon dimension/browse for where u put your picon folder/save.
As for sending of picon i prefer to send it manually using DCC program or if u know the folder u can send it using dreambox edit eg for 500C PLI images is var\tuxbox\config\enigma\picon type this in your picon box under option/profile/path for picons in Dreambox
Select open/directories for your bouquet folder/ok.
Right click on all the channel list/ set keep flag option to ON/ok this is to keep the channel intact/u can go on edit the service data, under flag option only Tick the 2nd box H (hide) if u don't want the channels to be display on your box like eg. those demand channels/save.
When u done editing all the channel list + bouquet & u r sure about it ,select FTP/Tick auto reload setting enigma 2 for 800 series only/send files to Dreambox/Reload settings on Dreambox/Restart enigma.
For 500 series send files to Dreambox/Reload settings on Dreambox/Reboot Dreambox.
Do not create any bouquet for E1 500C or else u can't use the 3 digit direct channel selection.
There will be some minor mistake entry don't worry edit it,then send it again. Congratulation now your list is intact the same as SH channel list.
This is the way i normally do if u guys knows a better way or something i miss please feel free to add & correct me.
This is for those file that is already arranged post in dl section,for new scan will be more tidious & time consume but still a good way to gain experience arranging from scratch
Thanks to all senior & even junior for sharing their experience & knowledge.
added new channel
For E2 Box only
562 WarnerTV HD
760 CNN HD
Open DB edit
PROFILES:
GENERAL:
Tick all box
FTP:
COLOR SCHEME:
ADVANCED:
PICON:
