SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • haido78
    • Jun 2012
    hi guys, i am very noob, could anyone be kind enough to tell me what to do step by step? i am using dm500-c. Thanks!
    • DBTraitor
      • Feb 2011
      • 616
      #77
      bro, be specific what you need..
      Update channel or flashing or............?
      A wise man learn more from a foolish question than a fool can learn more from a wise answer.
      • armourer
        • Jul 2010
        • 15
        #78
        Originally posted by DBTraitor
        Press the red button on the channel list and the reserve will be gone
        bro, this question answer few time liao
        Thanks bro got it.
        • ASTROBOX
          • 163
          #79
          Originally posted by armourer
          Hi seniors, i hv updated the latest bouquets on my DM800. But found there are many reserved channels, can i remove it as i find them quite annoying especially when u r searching the channels. So actually what is all the reserved channels for and what is the purpose? Can i removed it?
          All the reserved channels is for user could do a direct 3 digit selection of channels from RCU eg 101 Preview channels all u have to do is press 101 from RCU it will go to that channels if u don't want it than u can delete all the created bouquet then u have to scroll for channels selection or u can use the red button as DB traitor mention if u don't want to delete it
          • dommu
            • Jun 2012
            New to the forum. Will try working what is written when I get a chance to download the necessary files
            • ahbenghero
              • 32
              #81
              Thats why I created the bouquet in a way such that you can browse by category without the reserved channels but when needed, you can key in the channel numbers and get to the correct channels.
              • DBTraitor
                • Feb 2011
                • 616
                #82
                To newbies out there
                Just for your info, its very time consuming and tedious to do a updated bouquet and service list.
                If you done it before, you should know that you actually need to spend hours/days doing it.
                So if you have benefited from it, please thank ASTROBOX , abeltcb and ahbenghero for their tireless effort
                And not to forget SGDVB for creating online updating features. Although its no longer available, but many of us has benefited from it before. He is a very sincere and helpful senior among us.
                And bro Jastropheed for sharing his valuable experience and patience for explaining things to us in the forum
                • ahbenghero
                  • 32
                  #83
                  hehe...thanks bro, I myself have benefited alot from all of you be it in the forum or through PM!! Now i am just contributing what I learnt here and there, its not much compared to all the masters here yourself included!! hehe...Thanks once again for the recognition!! And of course thanks to all the rest who have helped me in a way or another!! =))
                  • leowyk
                    • Jun 2012
                    • 8
                    #84
                    Hi,
                    I am using a DM500C with darkstar 2. I have followed the instructions given by astrobox which is very detail. everything is gg very smoothly.
                    But when i restart my box, i am stuck at the darkstar 2 startup screen and it will keep flashing. Did i miss out anything impt? anyone face this problem before?
                    Thanks in advance bro.
                    • pekakbadak15
                      • Mar 2012
                      • 103
                      #85
                      Originally posted by leowyk
                      Hi,
                      No problem. Maybe u can try switch off and on and see if it the same problem.
                      • leowyk
                        • Jun 2012
                        • 8
                        #86
                        hi,
                        still cannot. i tried re-sending the bouquet and service list also cannot. still stuck at the main page. thanks for your reply bro. but any more ideas?
                        • ahbenghero
                          • 32
                          #87
                          hi,
                          which bouquet are you using? maybe you can try changing to another channel and see whether anything comes up. (Bouquet button on remote and browse to another channel.) if doesnt work, try ftp another bouquet in.
                          • pekakbadak15
                            • Mar 2012
                            • 103
                            #88
                            hi,
                            When u power on the set, it is stuck on that screen? I think u need to reflash yr box if like that but u will lose all yr settings. Did u backup yr keys n roms or image?
                            • leowyk
                              • Jun 2012
                              • 8
                              #89
                              I am backing up now. luckily i can still access my files through FTP. i read earlier that keys can be found in /var. but where can i find roms?
                              Correct me if i am wrong, image file i can always flash any firmware in. what is impt is the keys and roms right? because w/o it i can only watched fta channels.
                              • ASTROBOX
                                • 163
                                #90
                                Rom files is in var / scce did u use this images recently?
                                I used to use this images very good & can say stable only thing is not a maxvar so when u install plugins check your var size 1st,if possible use maxvar images for 500 & don't use images that pre installed 3 to 4 skin that would use up your var folder & what u experience now
