SGSH Bouquet 500C/800HD/800SE
This topic is closed.
Good effort bro. Picons set looks nice for yours and bro astro. See many "reserved" channels when press red button for all services and cables.xml is not included in the bouquet. Is it ok?Erm...Hope I didnt sound like a leech...Just helping out...
I edited ASTROBOX's Bouquet and arranged how they are being categorized.
Do give some comments be it good or bad. =)
Oh...That is for 800 series only I guess...Comment
Ftp those files that r not include in his bouquet like cable xml will do, mine i have all the files including satellite & terrestrial xml in the bouquet postedComment
Hi Bro,
May I know what did I do or didnt do? How come there is no cable.xml in the bouquet file? Only Satellite.xmlComment
Hy just registered today and I'm interested in dream box 500c as received one as present short while ago. I can configure it for free to air channels but nothing else what am I doing wrong?All discussion on DM SGSH Bouquet
In XML format for reference
Digital Kaos - Downloads - SG Bouquet 31032012 In Microsoft Exel Format
For E1 DM500C
Digital Kaos - Downloads - SGSH 25052012 E1 500C + Picon
For E2 DM800/800SE
Digital Kaos - Downloads - SGSH 25052012 E2 800 & 800SE + Picon
Open DB edit
PROFILES:
option/profiles/new profile/set your box model & ip address/the rest just leave as default/test ip connection/after successful select enigma 2 setting for 800 series/cable receiver for 500 series enigma 1/save profile/save.
GENERAL:
Tick box 1/3/4/enable zap function/save.
Tick all box
FTP:
Tick enable quick ftp send/issue reload command.
COLOR SCHEME:
Select whatever color u like
ADVANCED:
Tick Allow duplicate entries / display reboot
PICON:
Tick show picon for service/40X30 picon dimension/browse for where u put your picon folder/save.
Select open/directories for your bouquet folder/ok.
Right click on all the channel list/ set keep flag option to ON/ok this is to keep the channel intact/u can go on edit the service data, under flag option only Tick the 2nd box H (hide) if u don't want the channels to be display on your box like eg. those demand channels/save.
When u done editing all the channel list + bouquet & u r sure about it ,select FTP/Tick auto reload setting enigma 2 for 800 series only/send files to Dreambox/reload settings on Dreambox/restart enigma.
For 500 series after reload command/do not select reboot/ go to the box power off it wait for 10 sec than on back the power,Do not create any bouquet for E1 500C or else u can't use the 3 digit direct channel selection.
There will be some minor mistake entry don't worry edit it,then send it again. Congratulation now your list is intact the same as SH channel list.
This is the way i normally do if u guys knows a better way or something i miss please feel free to add & correct me.
This is for those file that is already arranged post in dl section,for new scan will be more tidious & time consume but still a good way to gain experience arranging from scratch
Thanks to all senior & even junior for sharing their experience & knowledge.Comment
Yup, the auto-reload box was checked.
**Update**
Imported from my box and managed to save with all 3 files present. Just wanna check the 6900 series of frequencies are redundant is it?
Anyway, have uploaded the updated bouquet file. Hope it helps. =)
I'm having the same problem, did everything as instructed by ASTROBOX, tried it 3 times, everything installs perfectly but I'm only getting FTA channels. When I switch to a SH cable channel it's black, but the program info is displayed at the bottom.
Another thing is when I power up the box, the transponder scan menu comes on even though my channels are loaded.
I'm using a Black Box 500 running OpenPLI software. Pls let me know if I need to give any other info, I'm very new at this.
Thanks in advance for the help.Comment
