FY800HD
  • num3000
    • Feb 2010
    • 5
    #76
    Dear master JD
    Can this firmware be use on fyhd800 III?
    This is the 1st hd box from fy which I got.
    Please advise
    Many thanks
    • jatrophaseed
      • May 2010
      • 589
      #77
      Yes it can be used. Put into USB and load from Menu setup, search the file, press ok, ok manual updat press update. Too many versions, I don't know their marketing model nor but jus put to Manual update shudder b ok.
      • psytoburnies
        • Jul 2013
        Hi guys,
        Is there any difference between the FY800 HD sets, e.g. FY HD800C VII, FYHDc -e? I know there are some differences in the set top box itself, like white and black colour. But otherwise, is there a difference in the internals?
        Thanks!
        • Bomchacha
          • Feb 2013
          • 117
          #79
          China side likes to create awareness by playing with the numbers just to get more sales.
          Very unethical. Any minor changes to the firmware, they will release as a new version. But everything is still the same. It may look a little diff.
          What I see so far
          FY800HD
          FY800HD - II
          FY800HD - III
          FY800HD - IV
          FY800HD - V
          FY800HD - VI
          FY800HD - VII
          FY800HD - VIII
          FY800HD - e
          MVHD800
          HDC888
          • num3000
            • Feb 2010
            • 5
            #80
            Thank you sir!
            • 1inuyasha
              • Jul 2013
              • 4
              #81
              Thanks alot can now watch new channels
              • jatrophaseed
                • May 2010
                • 589
                #82
                I hope to get the latest bouquet update with the 19yh July's 5 HD chn asap. Keep tuned in.
                • Bomchacha
                  • Feb 2013
                  • 117
                  #83
                  Its good to see that Master and Seniors provide some form of support for the FY boxes here
                  Otherwise the FY box users here has no one to turn to when problem arises
                  Upzzzz
                  • Polluxti
                    • Jan 2013
                    • 12
                    #84
                    Hopefully can see new firmware up.. at the moment master J's firmware listed here should be the latest. I understand from my supplier that white and black fyhd boxes has different firmware..
                    the black fyhd firmware is attached for those who needs a backup. note that it's the default firmware of the box I have.. it's indicated sw version 100 so you can go into your box menu to see what version you have..
                    still waiting for new firmware updates..
                    • 1inuyasha
                      • Jul 2013
                      • 4
                      #85
                      have tried both v100 and the one jatrophaseed have uploaded which is v2.1
                      v100 looks more sleek but can't tune to the latest channels, for v2.1 looks the same as v1.0 but can tune to the new channels
                      • lAwBoY
                        • Mar 2010
                        • 8
                        #86
                        How do i upgrade the firmware?
                        I insert the thumbdrive into the setup box and select upgrade usb.
                        The setup box did a reboot that all.
                        Did i miss out on any step?
                        Rename the unzipped files to upgrade.bin
                        and Flashed via USB thumbdrive.
                        • lAwBoY
                          • Mar 2010
                          • 8
                          #87
                          Hi all, i did a manual search n all my channels are messed up.
                          Can anyone please guide me how to i recover the starhub channels listing?
                          what frequency should i use?
                          • nelsonhtb
                            • 44
                            #88
                            Did the channels mess up after you upgraded firmware?
                            If yes, when first startup did you choose Country = Hong Kong?
                            Reinstall firmware and during first startup choose Hong Kong and rescan channels.
                            Channel sort = By LCN
                            • lAwBoY
                              • Mar 2010
                              • 8
                              #89
                              i did not manage to upgrade the software.
                              I manage to get back most of the channels after i did the auto scan.
                              Thanks bro.
                              • Polluxti
                                • Jan 2013
                                • 12
                                #90
                                v100 looks more sleek but tune to the latest channels, for v2.1 looks the same as v1.0 but can tune to the new channels
                                You are using which fy box? Black or white?
                                Sent from my Mobile on Tapatalk.
