FY800HD
  • DBTraitor
    • Feb 2011
    • 616
    #211
    Some answer may work for your box
    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
    • rekria
      • Aug 2013
      #212
      Doesn't Work For Mhd 600C. Don't Think It Will Work For Newer Versions Of Fyhd either. The Main Issue Is That The Set Top Boxes Just Won't Receive 135 Or 135.5GHz. Not Sure If A Firmware Update Can Solve This Issue. Or Is It A Hardware Limitation. AnyOne Can Advise?
      • NT-Social
        • 17
        #213
        Originally posted by DBTraitor
        Now sure if you could find your firmware here
        Lastest Firmware for MVHD/FYHD/TNHD white and black box
        Hi DBTraitor,
        i followed ur link and is the same link as suggested by dreamyeyes.. i tried the image and it works for TNHD 888
        just fyi for other TNHD 888 users.. the image for the white FYHD works for TNHD 888 too.. except it can only scan 229, 230 and 231.
        I am receiving alot of distortions though. Anyone else facing similar distortion issues and how to solve it?
        Last edited by NT-Social; 11 August, 2013, 10:31. Reason: updated post on successful scan
        • tammytan
          • Aug 2013
          • 15
          #214
          I thought it would be good to share here how I manage to get all the new channels here since I've got PM asking me on how I do it.
          1) Make sure you have the latest FW ( file should be FY.AP), not those on pg 7 here.
          2) select Menu/ Channel search / Manual search.
          3) At Frequency(MHZ) select 128 / 136 / 149 (do one frequency at a time) and Symbol at 6090
          4) Before you press ok to search,WAIT for the Quality bar below for signal strength first. If no signal shown, pressing ok will not get you any new channel. (It may take around 5-30 sec before you see the Quality bar showing signal and it may take a few try before you get it.)
          Channel 101 to 106 will be shown and 107/108 will be shown as unknownChl
          Remember all the new channels will be situated at the back and will not be in correct order. I just save them as FAV for easy access. Hope it helps.
          • cyrus666
            • Aug 2013
            • 21
            #215
            tried your fy.ap software but it is not detecting in my box fyr hd800c-vii. I even renamed the file to .bin it detects but when loading it says error.
            • tammytan
              • Aug 2013
              • 15
              #216
              Read somewhere only FYHD HD800C I II III are able to use this. My is first version FYHD HD800C.
              • cyrus666
                • Aug 2013
                • 21
                #217
                well .ap does not detects on the fyhd hd800c-vii pls do not put that file and try or rename it to .bin because your box might brick.
                • tammytan
                  • Aug 2013
                  • 15
                  #218
                  This is where I've downloaded the FY.AP file
                  post #8 (Dragon head)
                  • nelsonhtb
                    • 44
                    #219
                    Hmm, this file was from Jan 2012.
                    • rekria
                      • Aug 2013
                      #220
                      I'm using the MHD 600C which apparently is the latest White variant of the FYHD800 series. Managed to receive all channels including 229, 230 and 231. Channels 232 and 233 are stored in the 1000+ channel numbers. From the posts I've Read So Far, it is evident that the newer series FYHD STBs are unable to receive channels 226 to 228. This is because the STB is Unable to pick up any signals from freq 135 and 135.5GHz. Even the whole spectrum from 130 to 140GHz has zero signal strength!
                      I'm not sure if this can be solved through a firmware update or it's a H/W limitation of the STB. Any kind souls can advise on this?
                      • diet7up
                        • Aug 2013
                        #221
                        Hi guys can I update the firmware that u guys post earlier on set fyhd (hdc-800 sf-v2.1, hw-v2.0 & tndt800) for viewing bpl thanks
                        • 1inuyasha
                          • Jul 2013
                          • 4
                          #222
                          Hello those who wants all the BPL channels can rescan now at 135.5 6090 will work now
                          • ong26bj
                            • Aug 2013
                            #223
                            Hi, newbie here. I am getting pixelated and sometimes no image on these channels (Travel Channel HD, GINX HD, iConcerts HD, Fox Family Movies HD, CinemaWorld HD, Sky News HD & channel M HD) on my FYHD800C. These 7 channels were picked up on auto-scan at 482MHz, Sym6875, 256QAM.
                            Would appreciate if some master can advise on this. Thank you in advance.
                            • zhugeliang90
                              • Aug 2013
                              #224
                              Hi, me a newbie here can any one here help how to get channel 227-228 from TNHD HDC-800-E white setup box? As I m new new step by step pls thanks
                              • drakelord
                                • Aug 2013
                                #225
                                TAMMY, THANKS FOR YOUR ADVICE BUT IS THE SOUND AVAILABLE? THE SOUND FOR SOME CHANNELS IS NOT AVAILABLE FOR ME BUT NEVERTHELESS, REALLY THANKS ALOT
