Yeah ! I'm using 3800c. Last nite my MVD 600c white box suddenly can't watch, only can watch ch5, 8, chU. Did u guys got this prob ?
FY800HD
Just an update, I just rescanned and found the channels again.For those who have successfully scanned and able to watch BPL, can you still watch it today? I realised my channels for BPL are now showing blank screens. I tried rescanning but still can't find back the BPL.
How are the rest of yous?
Sent from my GT-N7105 using Tapatalk 4
Sent from my GT-N7105 using Tapatalk 4Comment
i notice this set sometimes need a power reboot, meaning turning off the power supply, waita few seconds and turn on again.
i experience twice after some 1 week on standby (meaning powered but set not turn on:red led) never turn my box will show black and cannot descamble or totally cannot even turn on with remote..
but after turning off the power adapter, wait a few sec, and reboot then all is well..
Sent from my Mobile Command Centre on Tapatalk.Comment
Hi balis, I also have a similar problem.. It is supposedly a signal problem and I wanted to install a signal booster but my home layout does not allow one.. However, I have noticed when u initially turn on the box.. Alot of pixelation occurs.. Leave it on for around 5 - 10 mins and everything will be ok.. That's how it is for me so farComment
0 channels detected, which is probably why it went back to the scan page.Comment
thanks tammy tan!! it worked!!
I thought it would be good to share here how I manage to get all the new channels here since I've got PM asking me on how I do it.
1) Make sure you have the latest FW ( file should be FY.AP), not those on pg 7 here.
2) select Menu/ Channel search / Manual search.
3) At Frequency(MHZ) select 128 / 136 / 149 (do one frequency at a time) and Symbol at 6090
4) Before you press ok to search,WAIT for the Quality bar below for signal strength first. If no signal shown, pressing ok will not get you any new channel. (It may take around 5-30 sec before you see the Quality bar showing signal and it may take a few try before you get it.)
Channel 101 to 106 will be shown and 107/108 will be shown as unknownChl
Remember all the new channels will be situated at the back and will not be in correct order. I just save them as FAV for easy access. Hope it helps.Comment
