highlight right click edit transponder data
Lastest SG Updated Channels for the upcoming B****P****L?
Hi brother, to tune for the *** new channel , please follow here ( only apply to DM800 HD)
1. press Menu
2. Setup
3. Service Searching
4.Tuner configuration
5. It appear Tunner A ........., Enable. Just press enter n go in
6.For all scan band US ... change them to yes. ( right arrow will do )
7.Only select QAM256 to be Yes
8.Change Scan additional SR from 0000 to 6090 ( one will do )
9. press ok to save changes
10. Exit out to auto scan
11.put clear before scan to NO first. before u press OK. If not all your old channel will be lost
That all , around 20 -30 new channel can be found
Enjoy brotherComment
1. press Menu
2. Setup
Enjoy brother
Hey man thanks!
I\m also trying to find out how to do it for the FY800HD VI and FY800HD VII.
But it's a great help! =-DComment
Yo boss, i've tried your method leh..
But after scanning, i din see any new channels.
WHere is it supposed to be?
Pai sae... stupid question.. :P
1. press Menu
2. Setup
Hi bro, under the zap back to service before tuner setup, do we set yes or no ? Btw, I noticed some of my channels don't match after scan. Example when I press 555 it gives me channel 559 instead, anyway I can fix this ? Appreciate some help here . Very noob in this . For 800se. ThanksHi brother, to tune for the *** new channel , please follow here ( only apply to DM800 HD)
1. press Menu
2. Setup
Found a nutune supplier from Taiwan.
I wonder if the quality and QC is much better than a china made product?
???q?l-AFEA wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
give u guys small hints: don't waste time on buyer new tuner for 800hd and 800se because clone tuner are working fine for *PL channel.if you like the post use the Like button located bottom right corner of each post
if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanksComment
I got 3 tuner modules extracted from brand new DM800HDse clones, problematic dealing with those half-frequencies, and they either can't received those 8 channel or just 3 channels.
But when I swapped with my spare brand new tuners, without meddle with any setting, the new tuners able to receive those channels with video and audio, no scrambled image.
I conclude, yes, tuner quality play a big part too.Comment
