DM500 and N3 upc card
This topic is closed.
  • mhalley
    • Oct 2008
    • 66
    #16
    @elhefe
    Any update did you get your card working yet
    • despdan
      • 544
      #17
      @elhefe
      try setting the cam to common interface then use tuxbox commander to start newcs first then mgcamd (var/bin OK on newcs then red button OK) that way you will see how far your getting.
      • elhefe
        • 85
        #18
        @ redevil
        having spoken to several people as well as my boxkey friend in poland we are 70% there is no rsa key. he said that the box im
        using is so old that i couldnt have an rsa key.
        at Desp Dan
        i need a bit of backround info if you have any on why i need newcs/mpsd and cccam why cant i use newcs/cccam directly as redevil suggests or at least thats what i think he is suggesting???
        vvvvvv confused
        elhefe
        • satman
          • 736
          #19
          want to pm me a copy of your newcs.xml and log of newcs starting manually in telnet please let me have a look..
          you can omit the boxkey etc...
          regards
          boom!
          • elhefe
            • 85
            #20
            NewCS SmartCard information\n----------------------------------------
            A Butter Team Creation
            Password :*
            Welcome to the NewCS console
            -> [ 00:31:57 ] [ KeymaN ] Adding key 0000002f24b8f3 type 0 on Provider 000000 for caid 1800 ID=0
            [ 00:31:57 ] [ KeymaN ] Adding key 0000002f24b8f3 type 1 on Provider 000000 for caid 1801 ID=0
            [ 00:31:57 ] [ Nagra ] DT$08 data not defined.
            [ 00:31:57 ] [ Loader ] Card 1801 on port /dev/sci0 failed
            [ 00:31:57 ] [ Loader ] Reader type 5 on node /dev/sci1
            [ 00:31:57 ] [ Sci ] Closing device /dev/sci1 [Handle=-1]
            [ 00:31:57 ] [ Sci ] Opening device /dev/sci1
            [ 00:31:57 ] [ Sci ] Could not open device /dev/sci1 [Might be in use by another process?]
            [ 00:31:57 ] [ Loader ] Reset failed ...
            [ 00:31:57 ] [ Loader ] Reader type 5 on node /dev/sci0
            [ 00:31:57 ] [ Sci ] Closing device /dev/sci0 [Handle=3]
            [ 00:31:57 ] [ Sci ] Opening device /dev/sci0
            [ 00:31:57 ] [ Sci ] resetting card now
            [ 00:31:57 ] [ Sci ] Reset
            sub -1/n
            -> [ 00:31:57 ] [ SockSrv ] Socket 9 hung up
            CCcam SmartCard information\n----------------------------------------
            Welcome to the CCcam information client.
            • elhefe
              • 85
              #21
              <?xml version="1.0"?>
              For setup-issues, look in readme.txt!
              If there are other troubles, try different forums or irc channels around )
              The configfile are NOT case-sensitive, and shouldnt care about dos/unix cr/lf.
              ** This is the example file for Dreambox/TD etc. that use SCI interfaces.
              <newCSconfig>
              <readers name="SCI">
              <device>
              <name>Lower Cardreader</name>
              <type>sci</type>
              <mhz>500</mhz>
              <node>/dev/sci0</node>
              <parity>odd</parity>
              <reset>normal</reset>
              <export>Yes</export>
              <enabled>Yes</enabled>
              <blocksa>No</blocksa>
              <blockua>No</blockua>
              <blockga>No</blockga>
              <boxkey>** ** ** ** ** ** ** **</boxkey>
              <!--<rsa>0000000000</rsa>-->
              <irdeto-camkey>0000000000000000</irdeto-camkey>
              <irdeto-camkey-data>000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000</irdeto-camkey-data>
              <crypto-special>No</crypto-special>
              <ipk>000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000</ipk>
              <ucpk>00000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000</ucpk>
              <PTShandshake>No</PTShandshake>
              <carddetect>yes</carddetect>
              <newcamd_port>10000</newcamd_port>
              <autosid>Yes</autosid>
              <Seca-PPV>no</Seca-PPV>
              <pincode>0000</pincode>
              <priority>round</priority>
              </device>
              <device>
              <name>Upper Cardreader</name>
              <type>sci</type>
              <mhz>600</mhz>
              <node>/dev/sci1</node>
              <!-- <boxkey>0000000000</boxkey> -->
              <!-- <rsa>0000000000</rsa> -->
              <newcamd_port>10001</newcamd_port>
              </device>
              </readers>
              <radegastserver>
              <enabled>No</enabled>
              <port>16000</port>
              <allow>
              <hostname>localhost</hostname>
              </allow>
              </radegastserver>
              <cache>
              <emm>20</emm>
              <ecm>-1</ecm>
              </cache>
              <debug>
              <password>NewCSpwd</password>
              <level>normal</level>
              <type>init</type>
              <output>console,tcp</output>
              <console_options>normal,init</console_options>
              <tcp_port>1001</tcp_port>
              <tcp_options>normal,init</tcp_options>
              </debug>
              <newcamdserver>
              <name>newcs</name>
              <deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
              <user>
              <name>local</name>
              <password>local</password>
              <port>12000</port>
              <au>on</au>
              <sidoverride>off</sidoverride>
              <spider>No</spider>
              <rate>2</rate>
              </user>
              </newcamdserver>
              </newCSconfig>
              • satman
                • 736
                #22
                this is problem in newcs, its missing keys or thinks it is or could be config problem,
                boom!
                • elhefe
                  • 85
                  #23
                  @satman
                  so looking at the config in newcs does everything look ok?
                  see im not quite convinced my boxkeys are correct. does this look like it might be the problem. the dude who done the extraction actually sent me 2 boxkeys as he wasnt sure which set of keys to try. the box doesnt have an rsa key as its quite old so i cant see what much else cann be wrong to read the n3 card any advise will be greatly appericated.
                  • despdan
                    • 544
                    #24
                    @elhefe
                    Did he send you a dump file or just 2 boxkeys ?
                    From what i have learned you get the RSA key from the UPC Nagra3 card. Did you send the box & card to him ? also was it to that Polish Site ? From what I have read he claims to be able to extract the RSA key by dumping from the box.
                    • elhefe
                      • 85
                      #25
                      i emailed him the day before and he replied back with the dump. he says there is no boxkey its a really old sagem and he told me it doesnt have an rsa key so if it doesnt have a rsa key why do i need one also.
                      yes its that polish guy alrite i need to get the dump to someone to confirm that the boxkey is correct been kinda busy this week helping a friend out with so flooding probs here in the city centre but getting back to normal
                      box has arrived home and the good lady has retaken her place in front of the tv so getting time to do this work is v limited so im open to suggestions as to what is the best course of action.
                      • despdan
                        • 544
                        #26
                        If you want me to take a look at the dump I will have a look at it. btw did you get a dump of the nagra2 card it might have a few clues ?
                        • satman
                          • 736
                          #27
                          the dumps will be reciever flash dumps
                          no card dumped, he has no rsa because his old receiver doesnt have RSA!...
                          boom!
                          • red devil
                            • Oct 2008
                            • 690
                            #28
                            @elhefe
                            ive read the flash on those boxes and the example below is what your after
                            unless the polish guy uses a different sw to me
                            FFFFFCEO----1111111111111111-FFFFFFFF22222222
                            the 16 x 1 is your bk and the 8 x 2 is your ird displayed backwards
                            • cozierj
                              • 9
                              #29
                              rsa
                              Is the receiver rsa stored in flash memory or TSOP
                              Regards
                              • Satguy Keano
                                • 162
                                #30
                                Guys I run a N3 polsat card on my linux pc.
                                Can I just let you know that CCcam will not clear nagra 3 if you use a N line to newcs.
                                You have to use mpcs in between.
                                Better still use newcs_1.67 to read card then use mgcamd_1.31 to decode.
                                Cheers
