NO CA FOUND/FILE TO BIG FIX
  • dema2
    • 57
    #106
    Hi dear friend for to solve this error " no ca found" very simple::
    use a native rs232 serial port, nullmodem cable
    software you find "dream up patched" on google
    find and download all second stage for your dream box 800hd clone, you will need to say wath sim card have on board, there is clone like mine that have sim 2.0.1, other with FERRARI CARD, the more older box have sim 2.0.0 or sim 1.0.0, download all second stage ssl 69 to 76d download all for ferrari ssl78f or all that you find, i have more of this pm to me i send, weel now repeir
    connect clone dm800 to serial port with null modem cable, dm no connect power
    open the soft dream up patched click connet, this ask to you to give on the clone dm 800hd, insert power, wait, soft charge the loader, about 2 minutes, after load the your Second stage no firmware complete, only the your second stage, flash, in about 5 minutes your dm is now in a new life, is ok... for any question ask to me , i do not have experience in chip tuning, i study from now..., but i am in sat from 1998...good work and repair
    best regards to all dema2 italy
    • dema2
      • 57
      #107
      connect clone dm800 to serial port e null modem cable, dm no connect power
      open the soft drean up patched click connet, this ask to you to give on the clone dm 800hd, insert power, wait, soft charge the loader, about 2 minutes, after load the your Second stage no firmware complete, only the your second stage, flash, in about 5 minutes your dm is now in a new life, for any question ask to me , i do not have experience in chip tuning but i am in sat from 1998...good work and repair
      • nemirno oko
        #108
        hello I have spent much time reading the forum for
        * ERR01: CA NO FOUND
        and I have not found an adequate answer in this regard, I hope someone has solved for this. When I turn on the receiver to the mains electric. network connections back of boxes in the same second you turn yellow and green lights for 2 seknde the display appears err01: no ca found. I used all DreamUp did not help. only when I connect dramUP 1.3.3.1. 232 cable message appears 12:12:11 box type: DM800 you can wait a year nothing was happening? I used to post here hipertrminal (c) 2007.2008 Dream Multimedia GmbH. All rights reserved.
        Dreambox DM800
        FIRST STAGE 1:00 BO23456 {}
        2ND STAGE OK, build # 76 (20,100,419)
        0000 - BCM board setup
        00000126,00000126,00000125,00000124,00000123,00000 133 {}
        0007 - fp init
        0008 - ca init
        CA invalid
        OLED found!
        NO CONFIGURATION DATA PRESENT. STOP.
        I hope to have a solution thanks
        board REV J
        tuner REV K
        SIM 2.01
        If there is a way help ppppp
        • Oshie
          • Apr 2011
          I've got the same problem what is the reason?
          • nemirno oko
            #110
            There is no reason for this I can not understand that that it will not start DreamUp
            • deffc0n
              • Aug 2009
              • 894
              #111
              Problem is Hardware
              • nemirno oko
                #112
                which part should be replaced
                • v2vboni
                  • Apr 2011
                  #113
                  Clone DM800 HD PVR -NO CA FOUND - showing www.dm7020.com
                  I need help, my DM800 HD PVR is not booting anymore it just keep showing the NO CA FOUND error.
                  *The problem, I did flash it with a wrong .nfi or firmware, but before I did that, it was detecting a DM7020 as firmware though my unit shows DM800 HD PVR.
                  Now, I need to know which firmware or bootloader to use with my clone DM800 HD PVR. Hope you could provide me the files and steps to identify. My SIM inside shows: WT00 3588
                  • gheribrahim
                    • May 2011
                    Thanx
                    pretty simple fix , mine took best part of an hour using null cable and crossover together , good luck
                    • SGDVB
                      • 210
                      #115
                      Why an hour? If using dreamup + null modem + straight lan should only be less than 5 minutes to flash an image for DM800.
                      • aldawsee
                        • May 2011
                        I FOUND SOLUTION FOR ( FILE TOO BIG)
                        guys use another dreamup software
                        i used ver 1.3.3.7
                        u can find it here
                        http://www.dreambox.it/tools.htm
                        search for it
                        ok the steps are as posted befor
                        1. unplug the dm800 and conected to pc usin serial cable
                        2.run dreamup new version and click concect and dont close it ever.
                        3. plug ur dm800 to power now u see flash when it finish ( all slots (green) pring dreamreapir in front of dream up to inable the flash button and then press dream logo so u can flash ur dm with ur boot loader. also kepp dream repair or inforcer running.
                        4. now u see the screen on ur dm800 showing diffrent signs i saw dhcp...>
                        5. plug the network caple so the dm800 show u ip on the led screen u can plug it erlier in step 3.
                        6. use the ip to flash ur dm with an image and now use ur web browser.
                        then ur dm800 is alive againe
                        • africatwin
                          • Jul 2010
                          Originally posted by acimate
                          Hi buddy, saw your pm, read this thread,
                          it will definitely solve as i have tried no only once, but few times.
                          hi Bro, anyway to flash DM800 without having the CA error coming out?
                          • ultrakiasu
                            • 128
                            #118
                            First, you must understand why the error appear in the first place.
                            If you bought the original non-cloned DM800, the bootloader is preloaded in the official Enigma2 firmware, and required conditional Access (CA) cards to work. The Dreambox DM800 is protected by a security chip is designed to stop clone builders from selling receivers which can run the enigma based software which runs on these boxes.
                            Obviously the clone makers had their own SIM cards which make loading of enigma software on their clone sets possible.
                            Thus there is a need to make the firmware to load drivers for these special SIM card.
                            As long the firmware u had flashed included the bootloader driver for the matching SIM card (1.0 or 2.01), then you should not have the CA errors.
                            • arseven
                              • Jul 2011
                              #119
                              Me too with same problem.
                              I appreciate you guys help, since i'm around this subject for many hours and nights.
                              CA NOT FOUND error appears when i flashed wrong image. After that, following suggestions from here, i tried to flash with null modem and lan cable. The error changed to
                              LOOK AT WWW. DM7020.COM
                              CA NOT FOUND
                              I bought my 800 clone with indication from seller that would have ferrari sim card ssl78f. Now I have some doubts about that since on the clone screen, when in http mode, is shows the message
                              FERRARI SIM CARD SSL76FF
                              Also on the webinterface, at the bottom of the screen where firmware upgrade is made, it is written:
                              Bootloader Version: Dreambox Second Stage Loader BUILD #59, built 20080509
                              I tried DreamUP_patched_by_forhike_and_natas and many other dreamups, getting error
                              "No CA found by 2nd stage loader, please contact support at dream-multimedia"
                              When i tried enforce, flash button is highlighted,I choose image, but I get error FILE TOO BIG
                              I think this error appears because dreamup disconnects himself.
                              With these dreamups, i get an ip adress on the screan, what allows me to try webinterface.
                              By webinterface, Flash runs untill the end (100.00 %) but when i restart clone, the error LOOK AT WWW. DM7020.COM persists on the screen
                              With dreamup 13.3.3.6 and 1.3.3.7, I don't get error, but after uploading flashloader, it stops in
                              UPLOAD COMPLETED, WAITING FOR ACKNOWLEDGE
                              if i force flash with enforce or dm800repair, i get
                              WAITING CHECKSUM and stops here. With these dreamups, i dont have any ip adress on the scren to try web interface
                              These is a complete report of what i'm facing...
                              What am i doing wrong?
                              The image i'm trying to use is for ssl76
                              I don't know what to do more
                              Regards to you all !
                              • DreamersDVB
                                • 245
                                #120
                                CA ERROR
                                I've done quite a number of DM800 CA ERROR and solved with enforcer or patch dreamup without a problem. Theres 1 one set(DM800)recently i have done everything like what you did,but still fail. Last option what i did was, swap simcard from my working box to the ca error box..And you know what the faulty box start and running again..I just need to either Dreamup v1334 or use lans cable>ip>mozilla>and flash newnigma2 bl82 image..Done as a Happy Man.
                                CA NOT FOUND
