NO CA FOUND/FILE TO BIG FIX
  • arseven
    • Jul 2011
    #121
    Thanks for your answer.
    If i well understand, you put a simcard from a working dreambox to the one with the problem.
    Then she started working.
    What you done next?
    You stay with the dreambox which didnt have the problem sotped because don't have simcard, you bought another simcard, or you manage to use the simcard which was in the broken dreambox?
    Just to know what should I do. Maybe I have to buy another simcard, since I don't have any other dreambox.
    Someone knows where to buy?
    • SGDVB
      • 210
      #122
      The sim 2.01 is not commonly sold as local seller will not get them unless they have very good relationship with their source.
      Even that most source in china are basically reseller & not direct distributor or factory. Only those who work with the factory may have chance to get hold of the sim.
      I may be wrong as your source could be a big time reseller but to what I know, there are only a few of them.
      Even you search on website selling DM box, the assy they sell only the tuner, adapter, remote. Not the sim card.
      What you done next?
      • SGDVB
        • 210
        #123
        Sorry... I did not see your this post.
        You are on ferrari sim? Please note that you can only use ferrari patch image & not the sim2.01 image.
        Clone box commonly use sim2.01. Ferrari sim is a total failure which the chinese try to come out to counter sim2.01 but they have fail.
        Sim2.01 has been widely known & has it full support by many other in term of patch image.
        Me too with same problem.
        I appreciate you guys help, since i'm around this subject for many hours and nights.
        CA NOT FOUND error appears when i flashed wrong image. After that, following suggestions from here, i tried to flash with null modem and lan cable. The error changed to
        LOOK AT WWW. DM7020.COM
        CA NOT FOUND
        I bought my 800 clone with indication from seller that would have ferrari sim card ssl78f. Now I have some doubts about that since on the clone screen, when in http mode, is shows the message
        FERRARI SIM CARD SSL76FF
        Also on the webinterface, at the bottom of the screen where firmware upgrade is made, it is written:
        Bootloader Version: Dreambox Second Stage Loader BUILD #59, built 20080509
        I tried DreamUP_patched_by_forhike_and_natas and many other dreamups, getting error
        "No CA found by 2nd stage loader, please contact support at dream-multimedia"
        When i tried enforce, flash button is highlighted,I choose image, but I get error FILE TOO BIG
        I think this error appears because dreamup disconnects himself.
        With these dreamups, i get an ip adress on the screan, what allows me to try webinterface.
        By webinterface, Flash runs untill the end (100.00 %) but when i restart clone, the error LOOK AT WWW. DM7020.COM persists on the screen
        With dreamup 13.3.3.6 and 1.3.3.7, I don't get error, but after uploading flashloader, it stops in
        UPLOAD COMPLETED, WAITING FOR ACKNOWLEDGE
        if i force flash with enforce or dm800repair, i get
        WAITING CHECKSUM and stops here. With these dreamups, i dont have any ip adress on the scren to try web interface
        These is a complete report of what i'm facing...
        What am i doing wrong?
        The image i'm trying to use is for ssl76
        I don't know what to do more
        Regards to you all !
        • tganet
          • Aug 2011
          Same problem !
          I Have same proble, how to resolve this !!
          TGAnet
          • alexys44
            • Jul 2011
            #125
            Hi guys! Same problem with a DM 800hd...i have tried several times Dreamup(2nd_stage_pack_Flicksters Magic Files) all technics and nothing_receiver connected with PC via Serial cable_db9(null modem),network cable to router(anyway no net connection at all_blocked)...Results:ERR01:no CA found!on the box display and"file to big" when trying to flash with Dreamup__seems no comunication between pc_dreamup_and receiver...Please someone help me !!!
            • alexys44
              • Jul 2011
              #126
              The error came after a webinterface image install image was ok but after the first reboot ,the box displayed the error ! I have tried to install a new image(DreamElite) because the box was very slow and heating to much(i used a cooler against heating_tuner!)...probably because of an old image installed by the seller...Thanks very much for help !Best wishes to all !
              • dwrath
                • Sep 2011
                I got a dm800hd. Ran the online upgrade and turned out it was a clone set. Now stuck with said error
                • lanimal
                  • Sep 2011
                  dream doesnt semms to tconnectto the box
                  i ve the same problem does any know where to fing second stage uploader in NFI that is no too big to load
                  Originally posted by dream_box
                  I still have "file to big" after your procedures!
                  What can i do?
                  • Lee1501
                    File too big FIXED !!! Read me.
                    FIXED for me !!!! Hi all, I had the file too big error for days, I eventually discovered that the fault was the serial cable I was using. I bought from ebay a NULL MODEM serial cable. (See ebay item 180481856158) With this cable, I didn't even need to use the enforcer program, dreamup worked as expected, it immediately recognised the box, the status bar increased and the flash button became available automatically. This time when I selected the file, it DID NOT report a file too big error. I'm very happy!
                    by the way. I plugged this cable in to a USB to serial convertor, and flashed with a modern laptop with USB ports only and no serial port.
                    I hope this helps
                    • paresh
                      • Sep 2011
                      800 SE (Clone) - R01: NO CA FOUND
                      Dear folks!
                      I have a cloned 800 SE and it is now showing this error "R01: NO CA FOUND". Yes I did system update last night and today it is broken (yes my fault and it serves me right!).
                      So what I have done so far to fix this:
                      1. Searched on the internet and found these tools and lots of recommended steps
                      2. Dreamup Tool
                      3. Downloaded 210-SSL82-LT7-Patched-By-Ferret-dm800se-20000101.nfi
                      4. Connected the DM800se to my lapton using USB service port behind the DM800se and other end to the laptop USB interface.
                      5. My Windows 7 detected the new port and installed all the drivers. The device is a Port - Silicon Labs CP210x USB to UART Bridge (COM4)
                      6. Rebooted Windows 7 machine
                      7. Switched off DM800se
                      8. Start Dreamup Tool
                      9. Click Connect and it connects
                      10. Ticked Box "Use Network"
                      11. Local IP (PC) shows my laptop IP address
                      12. Select one: I have selected my laptop IP address
                      13. Remote IP (Box): Blank because the existing IP is not even issued to any device!
                      14. Serial Port: COM4
                      15. Switch On DM800se
                      16. DreamUp finds the box and does some flash upload (this takes only 20 seconds or so)
                      17. It than gives me a message stating "Waiting for Acknowldgement..."
                      Thats it!
                      18. I have tried using the Dreamup Force version which enables the Greyed out Flash button etc... but with that I get another message "File too big!"
                      Ok I give up! **Please can some help me**.
                      Also some of the blogs mentions Modem Null Cable? Well on 800se you dont have the Modem Null Cable but only service port (USB) connection.
                      • yassinov
                        • Jun 2009
                        • 78
                        #131
                        Too much Steps on the classic method !
                        OptiFlasher make it easy for you !
                        -Run OptiFlasher
                        -Click Advanced
                        -Select Port
                        -Select Model
                        -Write Bootloader or Repair NO CA Found
                        -Do Job
                        regards , yassinov
                        • tv 800hd for sg
                          • Aug 2011
                          • 5
                          #132
                          How about the problems can be SG DVB PM.
                          DM800HD DM500C DM500 V Dm800se new configuration***12290;
                          • flyingp1g
                            • Dec 2010
                            #133
                            This d@mn err01 no ca is killing me. I cant get my dm800 to connect for no reason. The serial port is not communicating no matter what. I've tried all version of dreamup patched and not, ive changed 3 different computers, 2 cables (100% sure its null) null/null, null/usb, ive tried them all, also optiflasher,NFC, enforcer, everything.
                            I think its a faulty rs232 port on dm800, but again not sure.
                            Is there anyway to get to stop ip mode, jtag or anything???
                            Please help
                            • Decoder
                              • 46
                              #134
                              Please help
                              Hi flyingp1g I'm no expert (as you'll see from my posts!!) but are you sure it's null modem - I had same feelings till I went to M*pl*ns and bought what I knew to be a "proper" null modem cable. Was also missled with usb to adapter (didn't know how to tell computer/Dreamup what port it was using) but my new computer has 9 pin port - plugged new cable in and bingo away she went!! Also don't forget you seem to have to have the network cable plugged in when using Dreamup. Hope this gives you some help. Best wishes
                              • flyingp1g
                                • Dec 2010
                                #135
                                Ok this is how i solved the no ca found with my dead rs232 port..
                                I connected a working dm800 with patched dreamup with only serial mode, but on dreambox both serial and lan connected. After dreamup loaded, i unplugged the working dm800 and plugged the broken one with again both serial and lan on dreambox and when it powered up it went in serial mode with ip showing. Then i flashed it with a correct image through web browser (not dreamup anymore) and works great. Serial port still not working so i guess its dead.
                                Very important dreamup only in serial mode, when i tried it with both serial and ethernet mode it didnt work.
